QUESTION: Has anyone used biscuit joinery on 3/4" plyw
Postby halfdome, Danny » Sun Oct 09, 2005 11:56 pm
Look for Apple Plywood it is just as strong and comes in 4x8sheets, Danny[color=blue][/color]
halfdome, Danny
*Happy Camper
Images: 252
Postby Chris C » Mon Oct 10, 2005 10:31 am
Thanks, Halfdome, I'll try that. :thumbsup:
Chris :D
Chris C
Postby cracker39 » Wed Oct 26, 2005 7:41 am
I had to relay this info. I checked my biscuit slot widths, and found that the narrowest piece I could end cut a slot for #0 biscuit was about 2" wide. In the MLCS catalog, I found a router bit that cuts a round 1 15/32" slot for a 1 13/32" round biscuit (# 11). If you are very careful, you can cut a slot in the end of a piece as narrow as 1 5/8", or more comfortably, in a piece 1 3/4" with some room to spare. It's costly though, at #32.95 for the bit and 100 #11 biscuits.
They do have a single slot cutter for $12 in the 5/32" width, but it cuts a 1 7/8" diameter slot, so you're back to a 2" width piece of wood. But, this cutter also comes in a 5.2mm width so you can cut slots and use a strip of 5.2mm plywood as the "biscuit". That brings up possibilities. BTW, I did some conversions. 5.2mm is 0.205". 3/16" is 0.185" and 1/4"of course, is 0.25". So, 5.2mm is barely over 3/16", but under 1/4".
Their site is www.mlcswoodworking.com and they have LOTS of router stuff, as well as forstner, bradpoint, and countersink drill bits.
Dale
cracker39
Images: 233
Postby randy chesnutt » Wed Oct 26, 2005 1:31 pm
cracker 39, grizzly.com. cat. 2005 page 185. you will see biscuits model h3732 #ff that is the size i believeyou are looking for. i believe some call them picture frame biscuit. i don,t have any around i used up all my biscuits.so i can,t give you the measurement.
randy chesnutt
Images: 65
Postby halfdome, Danny » Wed Oct 26, 2005 2:23 pm
Another method to join 2 pieces of plywood, and I do this all the time, is to route a 1/4" slot and pull it together with Dog Bones ( drawbolts ). It is very strong, needs no clamps and you can bondo over the slot you route for the dog bones if desired. This is the common way counter tops are joined together. On my floor I used 1/2" Baltic Birch, it comes in 5x5 sheets, and routed a 1/4" spline of baltic Birch at the joint and glued and stapled a 5" wide piece of 1/2" B.B. over the joint. Then I dadoed a 1" x 7" piece of Poplar and glued it over the ply to cover it from the elements. Looking at my floor frame you would never guess it was done that way. :D Danny
Last edited by halfdome, Danny on Wed Oct 26, 2005 8:36 pm, edited 1 time in total.
halfdome, Danny
*Happy Camper
Images: 252
Postby cracker39 » Wed Oct 26, 2005 6:11 pm
randy chesnutt wrote:cracker 39, grizzly.com. cat. 2005 page 185. you will see biscuits model h3732 #ff that is the size i believeyou are looking for. i believe some call them picture frame biscuit. i don,t have any around i used up all my biscuits.so i can,t give you the measurement.
I checked my Grizzly catalog to see those. MLCS has picture frame biscuits too, called #H-9 on their site, 1 1/4" x 1/8". I'm not sure they're the same as Grizzly's, but the shape is the same as the H3732. The ones I was referring to (#11) are perfectly round and are for "cabinet or face framing".
Dale
cracker39
Images: 233
Postby angib » Wed Oct 26, 2005 6:17 pm
Beware - Thread hijack in progress
This discussion is nicely timed as I was watching a TV program on boat/ship construction techniques used by the Romans, and they used something rather like biscuits. They cut mortices in the edges of adjacent planks at intervals and fitted 'loose tenons' (ie, not part of either plank) just like rectangular biscuits, into both mortices and then fitted a pin through each tenon and mortice, and so hold the planks together. Clever, eh?
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby cracker39 » Wed Oct 26, 2005 6:28 pm
Andrew, I watched that program last evening. It was rawthah fascinating. Seriously, I never knew that Caligua took time out from his debauchery to have something constructive made like those two ships.
Dale
cracker39
Images: 233
