Chip wrote:Asian,,, did you shorten up the tongue or did you leave it long for easy backing,, I am debating cutting mine off but am waiting till I get close enough to find out just how long (min) I need,, and I want the body to be as close as practicle for wind to go voer tear off back of car rather than hit it dead center of the front,,thanks,,,,,,,,,,,
chipper
cracker39 wrote:Asian, you posted before I got mine posted. About the notching for the swingarm. How much trailer side is outside your frame...thickness that is? I know the swingarm has to clear the frame, but by how much, and which axle did you use? I'll only have 5.2mm (about 3/16") added to my frame, and I didn't think that would require any notching for the swingarm. The Dexter pictures make it look like the swingarm clears the frame by an inch or so, but that could be deceiving.
asianflava wrote:When I designed my frame, I wanted to put a tongue box on the front. Just a box to hold things I wouldn't want inside, charcoal, chairs, etc. After Dave broke his tongue, I kinda nixed that idea. Not that I'm going offroad or anything but I like the peace of mind.
asianflava wrote:My walls are 1inch thick (3/4 framing with 1/8 ply faces) and I'm using a Dexter #9. I found out later that there is another option for short spindles. If I had used these, the arms would clear the sidewalls without notching AND I would have the correct hub to hub distance. The 2 inch sidewall clearance is a bit too much for my liking, it was chosen based my width of the fenders. I didn't want the wheels recessed too far into the fenders, that would look worse than the 2inch sidewall clearance.
