Notch Cutout
Postby madjack » Wed Jan 25, 2006 9:36 pm
Joamon..using a jig saw...mark your cut line..use the jig saw and cut just shy of the line...use a sander to finish...if the arc is a pure radius, you can make a circle cutter outta a 6"x3' piece of ply or masonite that is 1/4"thick or less and use your router to cutout the notch
Postby Jim Marshall » Thu Jan 26, 2006 9:25 am
Since I used 1/4 inch strips glued together to form our wall frames, I plan to just add 3/8 strips of wood to our frame and leave off at the hatch, thereby creating a notch. This would be the easiest for me as our frame work is 1 1/2 inch thick.
Another question, since our sides will be 1 1/2+ thick, would it be better to have two weather strippings instead of just one, or would this cause problems?
I started out with nothing and I still got plenty left.
VOL-N-TEAR
Jim Marshall
Images: 63
Postby madjack » Thu Jan 26, 2006 11:06 am
..2 weather strips...I dunno, it might seal up so tight that when you openned it, the "back" pressure might cause it to "pop" open and hit ya in the chin :lol: ;) ...long as ya left 1/4"(or so) between them for the compression to expand into, there should be no problem
Postby mikeschn » Thu Jan 26, 2006 11:09 am
naw, two weather strips are not necessary.
Pick the style that goes best with your teardrop and run with it.
Postby Jim Marshall » Thu Jan 26, 2006 9:13 pm
Thanks Mike and Jack, I guess I will stick with one weather strip then.
VOL-N-TEAR
Jim Marshall
Images: 63
Postby Larwyn » Thu Jan 26, 2006 9:48 pm
Joamon wrote:What would be the best way ( or some ways) to cut this notch on a tear that is 50 or 60% built? I supose a router with a guide but I don't have a guide. I have alot of tools just not a guide for my router. Maybe I'll have to buy one.
If I decide to cut the notch, I plan to do it with a router. First I'll follow the curve of the area to be notched with a rabbit bit in the router (only problem is the rabbit bit I have cuts a 3/8" rabbit). Then go back over the same area with a pattern bit (top bearing). This should perfectly follow the imperfect curve that I originally cut with the jig saw. What more could you ask for...perfectly reproduced imperfection..... :thinking:
The notch will then be about 1/8" too deep but a bit of aluminum flat bar should cure that problem easily enough.
Larwyn
Larwyn
Mad Kilted Texan
Images: 210
Postby Jim Marshall » Sat Feb 04, 2006 9:26 pm
We are coming along on the little tear pretty good so far with all of ya'lls help. I cut our notch like Larwyn said he was doing with his router. it worked great. My question is, will 5/8 inch be wide enough, if not I can cut it a little wider.
VOL-N-TEAR
Jim Marshall
Images: 63
