Galley sides in fabric?
Postby Ira » Wed Jun 28, 2006 2:53 pm
antilies wrote:To be honest i've been lurking for the last month or so. I've wanted a TD for a while now, but was having a lot of troubel finding information on building one. I've got a LOT of ideas, but no $$$$$. But I'm confident that I'll own one soon enough.
BtW I hope that you have an oppertunity to try my glue thing above. It might not be waht you need in THIS particular situation, but it has been very usefull to me.
It dries clear on the surface though?
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby antilies » Wed Jun 28, 2006 3:09 pm
Depends on how much you dilute the glue.... If you mix it "thick" than it might dry with a "skim milk" kinda look to it. But remember the thinner you make it the more you have to use to get the same amount of stick. The trick it to let it cure on a low humidity day. Should be able to dry in about 3 hours depending on humidity and temp, however overnight is usually best.
antilies
