Recommended Tools
Postby doug hodder » Fri Jun 22, 2007 12:49 am
Arthur...so how many drums do you need to sand? talk about a specialized tool!!! :lol: :lol: Doug
Postby Elumia » Fri Jun 22, 2007 1:16 am
It should go without saying, but Sharp blades and bits. They cut better and are safer because it keeps you from pushing too hard on the tool or the work.
Mark
Elumia
Images: 15
Postby apratt » Fri Jun 22, 2007 2:30 am
doug hodder wrote:Arthur...so how many drums do you need to sand? talk about a
8) :lol:
Arthur,
ASL spoken here
apratt
Images: 16
Postby Bernoulli » Fri Jun 22, 2007 5:23 am
The best table saws for general use are belt driven. They are heavier, quieter and the motors last longer than direct drive. If you are cramped for tool space, Makita makes a fair direct drive, but the rip fence is marginal. Ebay or Craigslist are the best places to find these tools. With Craftsman saws, the older (50s are good), the better. Cast extensions are better than stamped steel. Most original equipment rip fences are crap. If it's important to you to cut wood bits to exact length, get a miter saw. I have a Dewalt DW708 compound slider that I like, but Deltas are available used for $50 or so. The best 10" blade is the Forrest Woodworker II.
Porter Cable makes a fine "trim saw" with a 4" blade. It's quiet and easy to use on thin stuff - plywood up to 1/2" for example. It's expensive, but worth it. If you want more power, the Skill worm drive is still the best.
Festool makes the best jig saw. Bosch's are good.
I believe the Porter Cable makes the best router.
The Stanley 60 1/2 low angle plane is the best of the less expensive planes for fitting work. If yo want to spend a lot of time with it, Google the WWW for how to tune one up.
Bernoulli
Postby dhazard » Sat Jun 23, 2007 11:07 am
I found that this was very helpful.
Many miles and many tears. Times were hard but now they're changing.
You should know that I'm not afraid.
dhazard
Images: 122
Postby Muggnz » Sun Jun 24, 2007 3:42 am
My favourite tool is my brain cell. Especially when I manage to recognise the conditions that will lead to my creating a unplanned feature. 8)
Which usually happens when I'm a bit tired & things have been going along a bit to smoothly.
Muggnz
Crybaby
Images: 34
