doug hodder wrote:On your trim, I'd plan on epoxy coating out the back side before install. Any water that can get in behind it will cause the top surface to eventually pop. I learned this the hard way.
If'n it were me, I'd use a 3M 5200 caulk/adhesive available in caulk gun sized tubes. It's made for below water uses, not cheap, but a lot better than a home type latex or acrylic caulk. You're probably gonna see some of the caulk when all done however. I thicken up epoxy with silica and install the trim so that I get a bit of squish, and wipe it down with a finger. That way I get a fairly clear "fillet".
I'd check with a marine place or you can order your cloth from West Systems Geougon (sp?) Bros. At least you get all the same stuff and as big as you need, comes rolled on a tube. Doug
DudKC wrote:http://www.westsystem.com/ss/epoxy-adhesion-over-stains/
Answered my own question. I am still interested if anyone else has used the Minwax and had success. West Systems did not have success with that particular brand, but other oil based stains did work. I am a fan of stained woods, but some of the natural looking TD's look good too, so I guess I'll just have to rethink this step and figure out what I want it to look like.
If you have a preferred stain not listed above, you can conduct your own adhesion test. Be sure to cut completely through the epoxy coating and use a high tack tape. If you have no preferred stain, consider WD Lockwood's water-based aniline dye stain. It has worked reliably under epoxy for many years
doug hodder wrote: People here have had failures with both, however, I'll go out on a limb and say that I'd bet that more CPES users have had issues as opposed to the straight epoxy types. It's all in the prep work/ application and top coating. With either method/product...you can't cut a corner and think it's going to be fine. It doesn't work that way. Others opinions may vary.
Doug
