My New Build
Re: My New Build
Postby Rhino Ray » Thu Jun 21, 2012 11:44 pm
Getting a bit closer to finishing. I only get to work on it for a couple hours after work per day. I getting the feeling that's all I do. I put the trim tape around the frames around the inside of the cabinets and varnished it with three coats. I then remounted the doors. I hope there's room to close the galley hatch.
The Fantastic vent is installed.
The diamond plate is on and I'm part way through putting the seals under the railing.
Tail lights are on. They are for a 49 or 50 Chevy. It still needs to be wired.
There is still a ton of work to do, I hope I get it done by July 4th weekend. 8)
The eleventh commandment: Ye that snoozeth loozeth. Selling real estate in ALL of Jefferson State (Northern California and Southern Oregon)
My Build http://www.tnttt.com/viewtopic.php?f=21&t=49746
Rhino Ray
Images: 60
Re: My New Build
Postby S. Heisley » Fri Jun 22, 2012 12:54 am
What a beautiful pair that Chevy and teardrop will make! :thumbsup:
Re: My New Build
Postby BillZ » Fri Jun 22, 2012 6:33 am
Looks great!
As fast as you work, I bet you will "finish". Keep in mind they are rarely ever completely finished. There is always something else you want to do.
If you are installing cabinet hardware, don't forget to make sure that it doesn't come in contact with the hatch. I almost made that mistake on my lower cabinet doors. I got lucky on the vertical spars but not with a horizontal cross piece. I had to install the knobs a little high of center to get it to work.
BillZ
Re: My New Build
Postby Rhino Ray » Fri Jun 22, 2012 7:31 pm
Thanks Sharon, that's the idea i wanted to use.
I will be close with the cabinets and I may not even put hardware on them if it won't fit. I may have to keep some of them closed with magnet closures. The hinge springs are not tight enough.
Took the Chevy to the levy and the radiator almost went dry. On top of everything else I now have to pull that and get it fixed. It wont last pulling a TD up some of the hills I'm planning to take.
I may need to get some galley latches from Grant to lock it down. The rest of the build will be easy, I hope. :NC I still have to make some drawers put on the counter top and install all the interior trim parts. It may go on it's maiden voyage without it being done and I'm sure it will be fine. :thumbsup: The only critical thing now is making sure that the galley hatch doesn't leak and the tail light work. Oh yea, I still need to instal a hitch onto the 52 and wire it for towing and electric brakes. Good thing I converted it to 12 volts. :beer: I have to be done with everything in two weeks as well as get my place ready for a family reunion. :? Did I mention I work full time?
Rhino Ray
Images: 60
Re: My New Build
Postby Rhino Ray » Sun Jun 24, 2012 12:53 am
I put in a full day on the TD and got a fair amount done. I am
resigned to the fact that it wont be completely done before I take it on a trip.
Installed the inside cabinets.
Wired the running lights, fantastic fan, interior lights and tail lihts. Also started on the gally hatch.
Rhino Ray
Images: 60
Re: My New Build
Postby Rhino Ray » Mon Jun 25, 2012 11:08 pm
I was able to adjust the galley hatch so it actually fits right! I had to trim about a half inch off the bottom. I will have to put some trim on it to keep the weather out and the skin tight.
Winding the project down, only a few more details left to do. Things like the battery box, trim all the seams inside and the galley, a latch for the galley door then skin it and magnet latches for all the doors. I also need to build a couple drawers and finish wiring the 110v circuits. :shock: I may take it camping without doing everything.
I will haul it to the DMV later this week to get it regrestered.
I have to get a new radiator for the 52 or I won't be taking it. :cry:
Rhino Ray
Images: 60
Re: My New Build
Postby Campin' Texan » Tue Jun 26, 2012 8:50 pm
Man that turned out great!
Do you have some type of black seal under the aluminum trim?
Campin' Texan
Re: My New Build
Postby pappaw » Wed Jun 27, 2012 11:32 am
yes, really super sweet Ray :thumbsup:
cheers
Image Cheers from Granny, Pappaw, and Cocoa (the Dachshund) Image
pappaw
Images: 14
Re: My New Build
Postby Forrest747 » Wed Jun 27, 2012 12:20 pm
Looks great
Please tell me there are fuzzy dice in teh trailer!
Forrest747
Cowbell Donating Member
Images: 447
Re: My New Build
Postby Rhino Ray » Thu Jun 28, 2012 12:21 am
Thanks Campin Texan. There is a layer of black seal under all that trim. I'm using a lot of that stuff. I do have fuzzy dice in the 52. Not a bad idea for the TD. I'm thinking that I may put a Jelly Belly decal on it! :lol: one of my friends couldn't rember "tear drop" so she called it a jelly bean. It kinda fits. :wine:
For the battery hooked up and the box secured today and did a little wiring on the 110. It is all functional now. Still a ton of details to finish up on. Once I install the hatch latches I'm good to go camping. :applause:
Rhino Ray
Images: 60
Re: My New Build
Postby Rhino Ray » Sat Jun 30, 2012 9:16 am
Installed the latches so I can now drive it down the highway. Went to the DMV and got it regrestered.
Worked a bit more on the electrical.
Rhino Ray
Images: 60
Re: My New Build
Postby Oldragbaggers » Sat Jun 30, 2012 9:23 am
Very beautiful!!
Life is sooooo good.........
Sail...camp....bike...repeat
Becky
Oldragbaggers
Images: 331
Re: My New Build
Postby Rhino Ray » Mon Jul 02, 2012 1:47 am
Installed the tow hitch receiver yesterday with a little (big) help from my friend Tim.
Image.
Worked on the electrical today. Don't worry, it will all tuck back and look good. I installed an isolatolr and a couple of circuit breakers. Monday eve I will finish it up and test it.
Rhino Ray
Images: 60
Re: My New Build
Postby Scouterjan » Sun Jul 08, 2012 10:35 pm
totally awesome, can't wait to see pictures of the TD hooked up to the chevy
Jan
Scouterjan
Iron Man
Re: My New Build
Postby Rhino Ray » Tue Jul 10, 2012 8:07 pm
Jan here it is.
Went on our first trip.
My sister joined my wife and me with her TD. We are having a blast. :D
Rhino Ray
Images: 60
