Hatch Masters
Postby JohnF » Sat Feb 18, 2006 5:00 pm
I posted earlier that I was fighting a spring-back problem. I received and installed this morning two draw latches (part #TC-341 from www.Reidsupply.com) and that solved the problem. The latches pulled in the bottom that was mis-matched by about 7/8-ths of an inch.
I was going to install some small ones anyway, but these 341 units (Austin Supply cat. page 571) are really beefy and probably worth the money.
John
JohnF
Images: 5
Postby Miriam C. » Sat Feb 18, 2006 5:20 pm
Hi all.
A little late getting in here but did anyone decide what to glue FRP to? I went shopping today and the 1/4 ply and 5.2 luan didn't seem very bendable. I am working alone so :worship: It would be nice to hide the upcoming boo boo's.
Miriam
Postby Gage » Sat Feb 18, 2006 5:28 pm
Miriam C. wrote:Hi all.
Miriam
Your right. Why do you want 1/4" ply. Won't 1/8" be just as good and bend a lot easier? If not, them I'm in trouble, because with the exception of my sides, I used 1/8" every where else.
Have a good day.
8)
Image Image Image
Gage
Images: 28
Postby len19070 » Sun Feb 19, 2006 12:14 am
Miriam
I use frp as an inside finish to my hatch, and the other side of it as a surface to laminate my aluminum to. frp has NO spring back. I use either formica contact cement or silicone as a glue. I don't cut the frp off at the end of the hatch ribs but extend it to the outside edge of the trailer. This gives a hatch a thickness of frp + .032 aluminum as a hatch edge. At that point any corner molding can be fassened to it. On the curve this is very thin & very strong.
Happy Trails
Len
len19070
Images: 24
