larger camper ideas
larger camper ideas
Postby willy3486 » Fri Jul 21, 2006 10:17 pm
i have a few questions on campers. After discussing it with the wife the teardrop is out of the question or at least will probably shelved. I don't want to put that much work into one and then she would never go. I will need something more roomier and one she can walk into. I probably will need one a minimum of 10 feet long, have about at least 6ft 4 inch ceiling and toilet to make her happy. I can get one of the shower tubs from ebay for less than 100 bucks. I am trying to locate one of the old "ham" types or scotty made types but have not seen any here in middle TN. . There was one here I really liked it was being pulled by a late 40s/early 50s model chevy truck I think was yellow. Does anyone have plans to that one or a link to pictures? I would really like one to build from scratch or one to rebuild completely. The reason is I have access to a lot of free wood and would prefer to payt as I need stuff. I really do not want to take a loan for one.
willy3486
Postby Miriam C. » Fri Jul 21, 2006 10:34 pm
8) Well Will you have come to the right place. Try the design lib. up top, Rob's cabin car, The member design section, Hum. There are a lot of designs going and a lot are stand up size.
Enjoy
Miriam
Postby madjack » Fri Jul 21, 2006 11:37 pm
Willy, Look up top at the "design library"...also checkout Dale's(cracker39) Squidget....................... 8)
Postby bsandey » Sat Jul 22, 2006 4:50 am
There are also a couple in the "Vintage Plans" above that may fit your needs. I kind of like the "Lil Guy" that listed there, and may someday give a shot at building one. But that will be several years away, if I do.
Bill ("Mutt")
"The more complex the mind, the greater the need for the simplicity of play."
bsandey
Postby angib » Sat Jul 22, 2006 7:08 am
This was my shot at the smallest trailer to carry a working shower:
Finding the space for a shower isn't that hard, but then you have to have a large water tank, a hot water system and a grey water tank. None of this lot is either small or light, so you have to build a fairly big trailer.
Len is building something very much like this right now - in his Yahoo album, scroll down to 'Shasta 1' to 'Shasta 6'.
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby Laredo » Sat Jul 22, 2006 8:12 pm
Hey Andrew -- do you folks in Blighty have those cool corner shower units with the curve on the front?
They look like a quarter-circle and generally have the drain in the center.
Laredo
Postby Mike Spicer » Sun Jul 23, 2006 9:07 pm
Andrew
Looks like is may be about 10' long???? and how wide is it?. What size are the beds?
Thanks
Mike
Home Built 4x10
Mike Spicer
Images: 14
Postby Gerald_G » Sun Jul 23, 2006 9:25 pm
I am working (slowly) on a project of a bigger size.
Here's a sketch of what I hope to end up with....
There is no plan, (except in my head), yet, but I am working on some cad drawings for my sidewall layouts. Of course the windows sizes are for my specific recycled windows, etc.
You can follow my progress in the following thread.
http://tnttt.com/viewtopic.php?t=9017
Gerald_G
Images: 85
Postby Ira » Mon Jul 24, 2006 7:30 am
Willy, does she want separate bedrooms too?
HAH! JUST JOKING!
Have you looked closely at Rob's cabin car? I think you can stand up in that, and the thing is drop-dead gorgeous. Has a shower, too.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby angib » Mon Jul 24, 2006 11:17 am
Laredo,
We have corner shower trays for use in houses but not special trailer ones, if that's the question. Our trailers are always a lot smaller than US ones - a 'monster' trailer here is only 23ft long, 7ft 6in wide and no slide-outs - so our fittings for trailers tend to be smaller too.
The latest wild idea seen in 'caravans' (=travel trailers) that's been copied from boats is circular shower compartments with semi-circular doors that rotate around inside them. Looks cool, but I think square works better!
Mike,
Body dimensions are: 128" L x 76" W x 84" H (excl vent). Length overall is 166". Beds are 78" long and 22" wide in their 'dinette' position - either they each pull out to about 30" wide or they are joined by the table to make a 72" wide bed.
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby Laredo » Mon Jul 24, 2006 7:37 pm
Angib:
we have them for houses too. recently at a KOA I saw a wheelchair-access one that was about 3x3 along the walls and 5' across the slant (straight-sided triangle, not the quarter-circle one). I thought that was kinda nifty; made me wonder how the teardrops4vets layout might put the idea to use, albeit smaller.
Laredo
Postby willy3486 » Mon Jul 31, 2006 6:35 pm
As far as seperate bedrooms don't give her any ideas. I saw the cabin car I thought was robs. I liked that but the wife woulld want more room. I doubt I could talk her into it. Thats the size I would like but its to much of a trouble to build something like that and not be able to get the family to use it.
willy3486
Postby Nytewyng » Mon Jul 31, 2006 9:17 pm
If you decide not to build but buy, the wife might like one of these http://www.tab-rv.com/
Rob and Deb Mangano
Nytewyng
Images: 30
Postby chadn » Tue Aug 01, 2006 10:55 am
This is a bit larger... 28' But you can check out the build at http://www.chadsprojects.com
If you need any design advice drop me a line.
Building A Home Built 28' Trailer
chadn
