New Idea for Budget Minded folks.
Postby fornesto » Tue Jul 25, 2006 11:13 am
I had a 12V revelation. For those who like to plug in to 110 at campgrounds, etc., why not modify a Malibu Light control box? A) They are pretty cheap and easy to come by on e-bay (~$10). B) They convert 110 to 12V so you could bypass the battery. If you wired it into all your lights and cig lighters, you could simply plug it in at the campground. It would run all your dodads. It probably even has some fusing mechanism in it.
Just a thought.
fornesto
Postby Boodro » Tue Jul 25, 2006 2:03 pm
Hey Fornesto , I looked into those but I saw that the wattage is pretty low. Most of them can only handle very low wattage bulbs . If ya run lights in the cabin , galley , porch plus other things like fans the wattage goes up quick. Just my thoughts. I use a battery charger as a dc supply, just plug it into ac & viola! DC! It handles all my needs & then some. Just the way I did it. Good luck . :thumbsup:
We are all travelers in this world , from the sweet grass to the packin house , birth till death , we travel between the eternities . ( Robert Duvall as Prentiss Ritter)
Boodro
Images: 101
Postby ogeer3 » Tue Jul 25, 2006 3:40 pm
Why not just use a power supply out of an old PC. They have a fair amount of 12V output for lights and such. You can just ignore the other outputs. There should be plenty of info on the internet on how to use them.
:thinking:
ogeer3
Postby rasp » Tue Jul 25, 2006 3:52 pm
i have Malibu Lights on my deck and they work great but all the control box is a 12 VAC stepdown transformer. no DC.
Thinking is more interesting than knowing, but less interesting than looking
rasp
Postby Dewayne_Mellen » Tue Jul 25, 2006 4:05 pm
Keep in mind that power supplies from computers are what's called switching power supplies. The voltage won't be correct until a minimum load is applied. Until that load is there I'm not sure what the supply will do.
Dewayne_Mellen
Postby BILLYL » Wed Jul 26, 2006 11:50 am
I have converted the computer supplies into a 12v charger for my son's RC cars. Works fine. Do a Google search and you'll find all you want to know on how to convert them - and how to handle the load (couple of big watt resistore abut 10 ohm should do it)
Hope it helps
Bill
"If your children ever find out how lame you really are, they'll
gonna murder you in your sleep...." Frank Zappa
BILLYL
Postby Gerdo » Thu Aug 03, 2006 10:49 pm
Will an automatic battery charger (connected to your battery) keep your battery charged safely while using the 12Vs? I have a charger on a big truck and "charge" the battery while I use the liftgate. I have had this setup on this truck for about 8 years with no problem. I haven't put my battery to the long test to see how long I can go without a charge (WalMart 110AH Deep Cycle) I should beable to last a week or so. (Fan and Lights)
Gerdo
Images: 156
