Generic Benroy floor attachment
Postby KA » Wed Jul 26, 2006 9:34 pm
Hi,
The Generic Benroy plans call for bolting the floor to the frame. Does this mean it is ok to drill holes in the chassis steel (mine will be 2x2 1/8 square tubing) or do I need to weld tabs to the frame and drill those. How much drilling can I do to a chassis before structural integrety is threatened?
Thanks. :thinking:
Kris
KA
Images: 9
Postby Nitetimes » Wed Jul 26, 2006 9:55 pm
Simple solution is use deck screws
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby Miriam C. » Wed Jul 26, 2006 10:02 pm
Ka,
I drilled mine. I think most people do. You, however are having your trailer made so I would go ahead and put some plate in the corners for bolts. Perhaps someone who has a picture will post one.
Miriam.
Postby madjack » Wed Jul 26, 2006 10:14 pm
Nitetimes wrote:Simple solution is use deck screws
...we used those ourselves....however we built the entire unit independent of the frame and the attached the "box" to the frame thru the sides...we drilled the wood with a 1/4" bit then the steel with the recommended 7/32....this kept the ply from "pulling" as the screw went into the the steel....
Postby KA » Wed Jul 26, 2006 11:01 pm
Thanks Miriam, Madjack, and Rich,
There is so much to think about.
Kris :thinking:
KA
Images: 9
Postby kartvines » Thu Jul 27, 2006 6:22 am
My scad-a-bout frame had tabs that was used to screw the floor to the frame
Image..Image..Image..
Image.
kartvines
Images: 37
Postby KA » Thu Jul 27, 2006 10:53 am
Thanks Kartvines,
It sounds like there are several ways to do this.
Kris :thinking:
KA
Images: 9
Postby heydave » Thu Jul 27, 2006 2:42 pm
Are the deck screws really strong enough? How many or how far apart would you space them. My frame is boxed and I was wounering how to attach the floor. If they are strong enough, that would solve that problem.
Thanks, Dave
heydave
Postby Nitetimes » Thu Jul 27, 2006 3:51 pm
heydave wrote:Are the deck screws really strong enough? How many or how far apart would you space them. My frame is boxed and I was wounering how to attach the floor. If they are strong enough, that would solve that problem.
Thanks, Dave
They are plenty strong. I believe I put 6 on each X-member, maybe 7.
You can see them across the front here.
We used them to hold the decks on heavy equipment trailers (2" oak) and I don't recall any boards ever blowing off.
They are actually stronger than your average 1/4" carraige bolt because they are hardened. Also no crawling underneath to put nuts on and tighten. :thumbsup: :thumbsup:
Rich
Nitetimes
7000 Club
7000 Club
Images: 194
Postby Nitetimes » Thu Jul 27, 2006 3:57 pm
Here's a couple of better shots.
You don't really need a whole lot of them, just enough to hold it down.
Rich
Nitetimes
7000 Club
7000 Club
Images: 194
Postby mikeschn » Thu Jul 27, 2006 6:40 pm
All of the answers I've seen so far work fine.
Typically I run a bolt thru the floor, with a nut underneath. Yes, you might want to consider a counter bore for the bolt head.
But you could use self tapping screws if you have enough of them...
You want to consider the shear strength of the bolts or screws when sizing them. Especially if you have to stop quick... (or if you get stopped quick). Can you imagine backing into a campsite, hitting a tree, and your teardrop body comes off the trailer cause your screws were too small?
:oops:
Postby fornesto » Fri Jul 28, 2006 10:20 am
I ran a bead of construction adhesive across the frame members as I layed the plywood down. Just a little more strength and a better seal I believe.
fornesto
Postby Lone Wolf » Fri Jul 28, 2006 4:57 pm
Dave there not talking about deck screws for a out door deck. But floor screws made for heavy haul trailers. They usually come in to Dia. 1/4"
and 5/16" in assorted lengths and yes they are strong enough usually only 2 screws per 12" wide flooring every X-member. To install drill 7/32" hole through wood and ream slightly and finish drilling through frameing. For 5/16" screws Same as above but 9/32" drill bit.
HAPPY TRAILS
Lone Wolf
Images: 6
Postby bledsoe3 » Mon Jul 31, 2006 3:03 am
Kris, I welded tabs and bolted thru the floor. I used a forstner bit to sink the head of carriage bolts. Here's some picts.
http://tnttt.com/album_ ... ic_id=1993
http://tnttt.com/album_ ... ic_id=2067
bledsoe3
Images: 112
Postby KA » Sat Aug 12, 2006 2:43 pm
Thanks for all the replies. I would be lost without this forum.
Kris :worship: :worship: :worship:
KA
Images: 9
