S.O.S Windows
S.O.S Windows
Postby KA » Fri Jul 28, 2006 12:13 am
HI,
I guess I did a bad thing to my salvaged aluminum windows by cleaning the aluminum with S.O.S. I'm informed by another post on the forum that the steel can imbed in the aluminum and then rust. Apparently the experts don't use S.O.S. pads on their aluminum for that reason. So, I guess my salvage windows are now educational materials and will soon become roofs for seed starting garden boxes. I have just flunked windows 101 and I'm not even to the measure twice cut once part of building yet. :oops: I did learn some things along the way and will probably buy some nice new windows from Grant.
Kris
KA
Images: 9
Postby Arne » Fri Jul 28, 2006 5:35 am
I looked at Grant's site, and he now has some black framed windows, so I may go there also... I can always do a little rounding on the corners myself.
Yes, aluminum can 'pick up' with abrasion as it is usually soft... but, on windows, I would not worry about it., you can always paint them if it becomes a problem....
I found a source for round cornered, half awning windows for 125 each (12x18).... which is cheaper than the 650 I got from a boat supply place. Screens included.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby KA » Fri Jul 28, 2006 11:09 am
Thanks Arne,
Is your window source on-line?
Kris
KA
Images: 9
Postby Arne » Fri Jul 28, 2006 11:16 am
They are, but have no pics.. I called them to get approx prices... getting windows is harder than I expected it to be.. I asked about black frame, round corners w/screens, 12x18 for 125.... Not sure I want to spend that much as I want 4 windows... may go to Grant and get them and then paint the frames.
http://www.dcmco.com/dcmwdcomp.htm
Arne
Mr. Subject Line
Images: 96
Postby KA » Fri Jul 28, 2006 11:26 am
Thanks Arne.
Kris :)
KA
Images: 9
Postby Chuck Craven » Fri Jul 28, 2006 4:21 pm
Kris!
I don’t think you totally destroyed your windows. If some of the steal from the SOS pad did get embedded, you can find it by using water to wet down the windows. Take a magnifying glass after they dry and look for the rust. Use 400 grit wet dry sand paper to sand out the rust spots.
Try it! You may salvage them any way. After all that give them a coat of clear varnish! :thinking:
Chuck
Chuck a new td builder
Chuck Craven
Images: 62
Postby KA » Fri Jul 28, 2006 4:24 pm
Thanks Chuck,
I'll try your idea. By the time I'm finished with these windows, I'll know them quite well.
Kris :)
KA
Images: 9
Postby Laredo » Sun Jul 30, 2006 9:53 pm
you can get much of it off with a stout magnet also.
Laredo
Postby KA » Sun Jul 30, 2006 10:40 pm
Hi Laredo,
Thanks for the good magnet idea. By the time I get my trailer built to the point the doors go on, the windows will have rusted if they are going to. It seems like each step and decision of this build is taking a long time, but I'm having fun so far.
Kris 8)
KA
Images: 9
Postby Arne » Mon Jul 31, 2006 6:58 am
Let 'em rust.... it builds character.. and since there must be so little of it (if any, realistically), it can only go so far... I would not fret about it.
Arne
Mr. Subject Line
Images: 96
Postby KA » Mon Jul 31, 2006 9:20 am
That's probably a good way to look at it, Arne. :)
Kris
KA
Images: 9
