Rot Doctor's clear sealant and camping
Postby kirtsjc » Fri Jul 28, 2006 7:53 pm
I am anxious to camp in my "Uglyender". However, it is still raw wood exterior!
In reading Rot Doctor's web pages, I get the impression that I can at least seal the raw wood with the clear sealant for now, so I can get some camping in...
Then as summer winds down, I can fill the bad spots, and when cooler less humid weather arrives, get down to the dirty nasty task of painting with epoxy....
Good move, bad move, neutral?
(There goes my goatee, have to shave it off to wear a respirator! :x )
Thanks!
kirtsjc
Images: 43
Postby Chuck Craven » Fri Jul 28, 2006 8:03 pm
I have been spending some time with them!
Good people to work with!
Yes put about 2 to 3 coats on. You will have to use an epoxy filler and epoxy pant after but most epoxies will stick to CEPS it will work just like a primer! :thumbsup:
Chuck
Chuck a new td builder
Chuck Craven
Images: 62
Postby mbader » Fri Jul 28, 2006 11:18 pm
We went on a 7 day trip to Colorado when the teardrop only had epoxy sealer on the outside. It rained 5 of the 7 days.
No damage to the wood.
Malcolm
mbader
Images: 9
Postby mikeschn » Sat Jul 29, 2006 4:59 am
Couldn't have said it better myself. :o
Postby kirtsjc » Sat Jul 29, 2006 5:53 am
Chuck, mbader & Mike: :thumbsup:
Thanks, just wanted to make sure my impression and what I have read here was correct!
Would hate not only to have water damage, but also hate to see layers of ChiPly peeling off at this stage... :?
Thanks again All!
kirtsjc
Images: 43
Postby BILLYL » Sat Jul 29, 2006 6:22 pm
Sounds like a plan. Just make it campable
"If your children ever find out how lame you really are, they'll
gonna murder you in your sleep...." Frank Zappa
BILLYL
Postby Melvin » Sat Jul 29, 2006 6:53 pm
Clear epoxy doesn't block UV so try to keep your tear covered when it's not in use, both for the cps's sake and so the UV doesn't degrade your plywood.
Commandant Louis Joseph Lahure has a singular distinction in military history - he defeated a navy on horseback. Occupying Holland in January 1795, the French continental army learned that the mighty Dutch navy had been frozen into the ice around Texel Island. So Lahure and 128 men simply rode up to it and demanded surrender. No shots were fired.
Melvin
Images: 14
Postby Steve_Cox » Sat Jul 29, 2006 7:54 pm
Melvin wrote:Clear epoxy doesn't block UV so try to keep your tear covered when it's not in use, both for the cps's sake and so the UV doesn't degrade your plywood.
Couldn't have said it better myself. :o :D
Steve_Cox
Images: 196
Postby kirtsjc » Sun Jul 30, 2006 7:43 am
Melvin & Geezer-Crossing:
thanks for sharing your experiences. "Uglyender" sleeps in a fully enclosed garage for now, and will in the future.
John
kirtsjc
Images: 43
