Page 1 of 1
Rot Doctor's clear sealant and camping
PostPosted: Fri Jul 28, 2006 7:53 pm
by kirtsjc
I am anxious to camp in my "Uglyender". However, it is still raw wood exterior!
In reading Rot Doctor's web pages, I get the impression that I can at least seal the raw wood with the clear sealant for now, so I can get some camping in...
Then as summer winds down, I can fill the bad spots, and when cooler less humid weather arrives, get down to the dirty nasty task of painting with epoxy....
Good move, bad move, neutral?
(There goes my goatee, have to shave it off to wear a respirator! :x )
Thanks!
PostPosted: Fri Jul 28, 2006 8:03 pm
by Chuck Craven
I have been spending some time with them!
Good people to work with!
Yes put about 2 to 3 coats on. You will have to use an epoxy filler and epoxy pant after but most epoxies will stick to CEPS it will work just like a primer! :thumbsup:
Chuck
PostPosted: Fri Jul 28, 2006 11:18 pm
by mbader
We went on a 7 day trip to Colorado when the teardrop only had epoxy sealer on the outside. It rained 5 of the 7 days.
No damage to the wood.
PostPosted: Sat Jul 29, 2006 4:59 am
by mikeschn
Couldn't have said it better myself. :o
PostPosted: Sat Jul 29, 2006 5:53 am
by kirtsjc
Chuck, mbader & Mike: :thumbsup:
Thanks, just wanted to make sure my impression and what I have read here was correct!
Would hate not only to have water damage, but also hate to see layers of ChiPly peeling off at this stage... :?
Thanks again All!
PostPosted: Sat Jul 29, 2006 6:22 pm
by BILLYL
Sounds like a plan. Just make it campable
PostPosted: Sat Jul 29, 2006 6:53 pm
by Melvin
Clear epoxy doesn't block UV so try to keep your tear covered when it's not in use, both for the cps's sake and so the UV doesn't degrade your plywood.
PostPosted: Sat Jul 29, 2006 7:54 pm
by Steve_Cox
Melvin wrote:Clear epoxy doesn't block UV so try to keep your tear covered when it's not in use, both for the cps's sake and so the UV doesn't degrade your plywood.
Couldn't have said it better myself. :o :D
PostPosted: Sun Jul 30, 2006 7:43 am
by kirtsjc
Melvin & Geezer-Crossing:
thanks for sharing your experiences. "Uglyender" sleeps in a fully enclosed garage for now, and will in the future.
John
