bledsoe3
You were correct, I can park under it.
Kens
I had to install my own grommets, the ones on the tarp didn't match up with the frame.
The top tarp is attached to 1/4" bolts at the top of each corner and the top center part of the frame.
The side tarps are also attached to these corner bolts and the front of the side tarp is attached by bungee cords to a I-bolt in the center. I'll use a shower curtain that will open or close for the front.
If you look at the top of the camper near the vent you can see a PVC frame that is 8" higher than the vent cover. This frame keeps the tarp off the vent so I can open the vent.
