Is there a way to get the dents to pop out without ruining my plywood walls?
2. How do I deal with the seam line the glue left. It is quite visible.
Thanks
Aunti M
Miriam C. wrote:
I am going to stain and clear coat it if I dont mess it up too bad between now and then. :oops:
Thanks for helping
Miriam
you could run a piece of wood trim over that seam to conceal it.
not sure about the dents though........I cant see them in the photo.
_________________
Sam I am wrote:The wet cloth and iron idea might work well. I have used that method to remove "hangar rash" dents on model airplanes for years. It works well on balsa and 1/8" thick Lite Ply, which I believe is birch with a balsa core. Try it on a scrap of your side material.
doug hodder wrote:whatever you do...just be careful and don't blow through the top veneer with the sandpaper...then you got problems, especially on a woody...I've had good luck with water and low heat...Doug
