Victor Star wrote:The top is covered with marine grade vinyl. It has some UV ratings that make no sence to me at all but I thought I'd take a chance. I did a lot of testing and as long as I get a good seal on the edges it should be water tight.
Victor Star wrote:After several different tests I wasn't happy with the look so I just stretched the vinyl and stapled it 1/8" from the edges. I tried contact cement, urethane, and PL adhesive but couldn't get it as smooth as I wanted. I'm going to fold the edges back and lay down a bead of silicone to hopefully seal it. If I get any kind of hole in the vinyl I'm sure water will wick it's way in. The top was sealed with a couple of coats of spar urethane so I'm not worried about that.
