Roof Attachment
Roof Attachment
Postby spadefeet » Tue Aug 15, 2006 2:30 pm
Second day of my TD build and I am now ready to attach roof. I have stringers every 12" so what is the best way to attach some luan to the top? Glue, epoxy? Screws no screws? One key factor is whatever I use must come from HD or Lowes. As you can probably tell I am new to the TD community. Thanks.
spadefeet
Postby oklahomajewel » Tue Aug 15, 2006 2:33 pm
Welcome Spadefeet :thumbsup: ... there are no dumb questions, believe me! haha
I have not put my roof materials on yet, but hopefully in the next week.
I am going to use 1/8" luan , and adhere it to the spars with a Loctite product in a caulk tube that I've heard is really good , or use something like the PL type glue (Gorilla Glue)
and shoot brad nails into the spars to secure the hold. I think this is what lots of others have done.
I'll be interested to see the replies here.
Julie
oklahomajewel
Images: 82
Postby asianflava » Tue Aug 15, 2006 3:26 pm
I used PL Polyurethane caulk to glue it down and brads to hold it there while it sets up. Short screws with broad heads would work too, I'd probably remove them later. I skinned with aluminum so it covers up a multitude of sins.
asianflava
Re: Roof Attachment
Postby Steve_Cox » Tue Aug 15, 2006 7:05 pm
spadefeet wrote:Second day of my TD build and I am now ready to attach roof. I have stringers every 12" so what is the best way to attach some luan to the top? Glue, epoxy? Screws no screws? One key factor is whatever I use must come from HD or Lowes. As you can probably tell I am new to the TD community. Thanks.
SF,
There are almost as many answers to this question as there are TearDrops.
I'm from the thickened epoxy and no screws, nail or staples crowd. Actually not a crowd, maybe I'm the only one that didn't put holes in my roof plywood to hold it down...Just epoxy and clamps..... lottsa clamps.
Second day, hmmmmm......... I think I was tacking up the frame with the welder on the second day. :D Guess you'll be finished by the end of the week. :lol:
Steve_Cox
Images: 196
Re: Roof Attachment
Postby Miriam C. » Tue Aug 15, 2006 7:28 pm
Second day huh. Well I guess thats why we don't have any pictures 8) 8) 8) :lol: :lol:
Spade, take a break and get the camera. Someday you are going to really want them.
Aunti M
Postby Darren » Tue Aug 15, 2006 7:41 pm
Welcome to the forum. I used Gorilla Glue on the spars and sides then stapled along where the roof met the walls. If you have some tight radius' to go around be sure to have some strap clamps ready.
Darren
the camper formerly known as Victor Star
Images: 161
Postby mikeschn » Tue Aug 15, 2006 8:32 pm
I used Stainless steel screws in my 1/4" birch roof.
But for 1/8" luan in the past I have used staples in a pneumatic stapler. Don't set the pressure too high. I typically use titebond III in between the luan and the spars. After you glue and staple, be sure to get inside with a wet rag and wipe off the excess.
Postby Micro469 » Tue Aug 15, 2006 10:26 pm
Shooting brads into 1/8" ply can be tricky. When I tried it, no matter how I set the pressure, I either went right through the ply or the nailer wouldn't fire. What I tried was to get a scrap piece of ply, lay it on top, and shoot the brad through both pieces. The brad would go all the way through the first piece, and end up flush on the piece I wanted to nail..No more worries. ;)
John
Micro469
Images: 382
Postby Nic » Fri Aug 25, 2006 5:19 am
I used Liquid Nails Construction Glue for each rib and the tops of the side walls. Then i started at the front/bottom and started tapping small nails in one at a time at the top of the side walls. To make sure that my roof skin was going to make use of all that construction glue on the ribs (where i would have no nails) i made use of my straps. I placed boards above the spots that i had ribs. Stretched the straps from the fron to the back and when i would tighten the straps the boards would push down on the skin real even. I let the straps and boards stay on for two days just to make sure i had a good hold. All my nails are going to be covered up by wood trim. Its holding up very well and the construction glue (im told) allows for some play when the camper is beating down the highway. If you look close you can see the glue on the ribs on one or more of my pix.
Im not lazy. I just hang out a lot.
Nic
Images: 169
Postby GPW » Fri Aug 25, 2006 8:41 am
We used the suggested LNHDC Adhesive and 1" serrated brad nails ... then sealed all with fiberglass tape and epoxy resin .... STRONG Like ROCK !!!! :thumbsup:
Users browsing this forum: Google [Bot] and 2 guests
