by Miriam C. » Sun Aug 20, 2006 6:43 pm
Brian,
Let me be the first to tell you that you really don't need to coat the inside with CPES unless you are using it for a shower. Any finish will do it.
I am building with wood, foam and wood walls so I coated the inside (hidden) walls with floor polyurathane I had around. Some are using paint. I did this to protect the ply from moisture.
My final inside walls will probably be the same poly floor finish or an amber shellac. (I have 5 gallons of it.)
Aunti M
