Simple measuring trick
Masking tape!
Not working to plans and building by eye has its drawbacks, one of which is having to guess with measurements.
A steel tape sucks for trying to measure around a radius, especially when there is nobody to hold the other end. (Jake could do it, but he gets the tape all slobbery.)
Last weekend, after measuring the door opening for trim for the umpteenth time and getting the umpteenth different measurement (and forgetting which block of wood I had scribbled the measurement on), the light went on.
I carefully taped the inside of the door opening (at halfway point) with masking tape making sure not to stretch the tape, marked my beginning and end points, carefully pealed the tape off and taped it to the edge of the workbench, overlapping the corner with one of the marks. Pulled out the ole trusty steel tape and measured from the corner of the workbench to the mark on the tape. Voila! Remember, this is a rough measurement cause the tape might have stretched, but it gets the measurement pretty damn close. This method would have also worked for marking spar locations on the wall. Do it in reverse. Tape on the workbench, mark the spar locations, peal the tape an put in on the edge of the wall and transfer the marks. This method when done with a stick of wood is called "story boarding."
I love to find ways to cheat on measuring!
