Page 1 of 1
Piano Hinge Question
Posted:
Sun Sep 10, 2006 9:33 am
by kayakrguy
Hi Folks,
I am at the 'order the hinges' stage.
I am going to use piano hinges on doors.
Would appreciate advice on where to get same and whether they need to be offset or not....some people do some don't?
I know that stainless steel is preferred material and will stick with the group's wisdom on that <g>
Many Thanks and Encouragement to all!
Jim
Posted:
Sun Sep 10, 2006 10:09 am
by madjack
Jim, we got ours at Austin Hardware...check around for local sources to save on shipping...avoid anyplace that has "marine" in their name...don't know if they sell hinges but Fastenal is an excellent souce for SS hardware (screws and such)...
ps...when I get over to the shop, I will look up that part# forya
Posted:
Sun Sep 10, 2006 3:18 pm
by asianflava
Got my door and hatch hinges from Grant (Lil Bear Tag along). The extra bend in the hinge really stiffens up the door to avoid the dreaded warpage. The offset also gives you room for weatherstripping.
I'm really happy with them. However, if your doors and/or wall is much thicker than 1" you might not be able to get them. Call or E-mail Grant to make shure.
I got some of my stainless fasteners from an eBay seller. He was good because he sold variety packs. The bulk of the fasteners I bought came from Fastenal. You have to buy at least 100 at a time though (or at least I did).
Posted:
Sun Sep 10, 2006 3:26 pm
by Ken A Hood
http://www.stainless-hinges.com/hinge_t ... hole_specs
They can custom form hinges for you, and the have several differnet styles, countersunk holes, no holes punched holes; as well as different knuckle configurations..
Posted:
Sun Sep 10, 2006 8:20 pm
by JunkMan
I got mine from Fastenall this spring. They had several different sizes availible, but did not carry all at the local store (but they wrere able to get them).
Posted:
Sun Sep 10, 2006 8:30 pm
by Steve Frederick
Jim, Check my PM!
Posted:
Mon Sep 11, 2006 3:23 am
by surveytech
Fastenal has a local store here and they were able to get them for me in about 2 days from Atlanta.
Saved shipping costs.
Hinge pin question...
Posted:
Tue Sep 19, 2006 4:38 pm
by kayakrguy
Folks,
Doors, internal seal plate (?) all sanded, ready to 'spot' --line up hinges on wall and door for FUTURE installation after the walls are up etc.
My question is: The pin in the piano hinge can drop out, either top or bottom...how to prevent without binding the hinge? I have searched the board archives and can't find anything dealing with that question, though hinges seem to be a VERY popular topic <g>
Thanks again,
Jim
Posted:
Tue Sep 19, 2006 5:01 pm
by madjack
Jim. take a punch, cold chisel or just a hammer and give the bottom most knuckle a good whack(or 2) or to be technical..."peen" it............
Posted:
Tue Sep 19, 2006 5:07 pm
by Steve Frederick
madjack wrote:Jim. take a punch, cold chisel or just a hammer and give the bottom most knuckle a good whack(or 2) or to be technical..."peen" it............
Check my PM Jim! Jack's got the plan!!
Posted:
Thu Sep 21, 2006 6:41 am
by kayakrguy
Finally, a technique I have experience with..when in doubt, just give it a whack! <g>
Thanks guys--I did both ends just to be safe <g>
Jim
Posted:
Sat Sep 23, 2006 11:37 pm
by Roly Nelson
I picked up my 48" piano hinges from Home Depot for about 10 bucks each. They are over 3 years old now, no leaks and no rust, so far. If I do have a problem, I'll replace them with duplicate new hinges. I did weatherstrip all around the doors, which BWY are all wood.........of course.
Roly, building simple........and cheap!
Posted:
Sun Sep 24, 2006 2:04 am
by Chaotica
Roly Nelson wrote:I picked up my 48" piano hinges from Home Depot for about 10 bucks each. They are over 3 years old now, no leaks and no rust, so far. If I do have a problem, I'll replace them with duplicate new hinges. I did weatherstrip all around the doors, which BWY are all wood.........of course.
hmm.......does this mean Roly's all wood tear isn't really all wood?
Posted:
Sun Sep 24, 2006 2:34 am
by madjack
Chaotica wrote:Roly Nelson wrote:I picked up my 48" piano hinges from Home Depot for about 10 bucks each. They are over 3 years old now, no leaks and no rust, so far. If I do have a problem, I'll replace them with duplicate new hinges. I did weatherstrip all around the doors, which BWY are all wood.........of course.
hey, it's all wood...except for those parts that aren't
