NASA Duct / vent
NASA Duct / vent
Postby GPW » Thu Sep 21, 2006 6:11 am
We've discussed before the elimination of the Roof vent and going to something more practical ... Here's some links to the NASA duct , an very efficient , low drag air scoop .... would make a perfect vent on TD and looks COOL too !!! Check it out for yourself ...
http.//naca.larc.nasa.gov/reports/1948/naca-rm-a8a20/ http.//naca.larc.nasa.gov/reports/1948/naca-rm-a7i30/
Sorry , Gov site is being uncooperative(typical ) .... here's some commercially available for race cars
http://www.discoveryparts.com/cgi-bin/s ... ct=ducting
try this ... http://www.recumbents.com/wisil/nacaduct/naca-duct.htm
Postby Aussie Nomad » Thu Sep 21, 2006 7:12 am
Having used "NACA" ducts on race cars they would not be any good on a teardrop owing to the large amount of water they pull in with the air when it is raining.
Ian. :D
Aussie Nomad
Postby GPW » Thu Sep 21, 2006 7:16 am
Ian ... I think the idea was to use them in reverse as a vent ....
This was a different approach to the same old vent thingie'...Something that would be easy to construct (we've made em' for airplanes for years )... Look COOL , and function to ventilate the cabin without the usual pop up vent on the roof (a source of leaks here in La. ) or the old school hole with a screen ... just something different to consider... :thinking:
Postby Aussie Nomad » Thu Sep 21, 2006 7:53 am
The don't draw air in reverse. You might as well leave a window open.
Ian. :D
Aussie Nomad
Postby EZ » Thu Sep 21, 2006 8:30 am
Cool as they would look, they only work when the vehicle (airplane, treardrop, race car, space shuttle) is moving.
Ed
EZ
Images: 72
Postby GPW » Fri Sep 22, 2006 8:00 am
Guys , don't get carried away with it's uses in the" real world" ..... I merely proposed this as a better" looking" replacement to the assorted venting techniques already used.... Vent ... to allow oxygen to enter so the occupants don't suffocate ...nothing about forcing or drawing air in .... merely a Hole !!!!! OK!!!
Postby PaulC » Sat Sep 23, 2006 6:23 pm
GPW, Don't sweat the others as some only look inside the square :lol: I understand the original usage and your proposed remedy for a problem with our little sealed boxes 8)
Cheers
Paul :thumbsup:
PaulC
3rd Teardrop Club
Images: 36
