Page 1 of 2
Paint seal
Posted:
Fri Nov 03, 2006 12:36 pm
by Jst83
I'm still coming up with my exterior cover I'm leaning towards a paint job. Just wondering what would be a good sealent to put over paint to help protect it from sun, weather, wind from pulling it?
Thanks for any advise on what you used. Scott
Posted:
Fri Nov 03, 2006 12:46 pm
by oklahomajewel
Good question.... I've sanded , primed, sanded, primed and waiting for a nice November day to do the painting.
I am wanting to get a good exterior paint . I think any exterior paint made for houses and barns would already have the protection for UV etc.
Julie
Posted:
Fri Nov 03, 2006 12:51 pm
by Jst83
oklahomajewel wrote:I think any exterior paint made for houses and barns would already have the protection for UV etc.
Julie
Very true, but what about the wind wear. 8 hours at 65mph I don't figure any house takes that.
Posted:
Fri Nov 03, 2006 2:40 pm
by b.bodemer
Like Julie...........I am waiting for a good day to paint(but here in Cleveland that might not be until spring time) and I'm using exterior primer and house paint on my wood trim.
Maybe others who chose to paint will post also.
Barb
Posted:
Fri Nov 03, 2006 3:14 pm
by Loader
I used marine topside paint, figured if it could handle the winds/waters it should be able to handle towing/camping. Plus, our tear is stored in the garage.
Posted:
Fri Nov 03, 2006 3:31 pm
by rasp
Interlux - Brightside Polyurethane is a great paint to work with IMHO. it is a marine topside paint, also.
can be had from
http://www.jamestowndistributors.com/userportal/main.do
James town has a nice selection of fasteners and hardware.
Re: Paint seal
Posted:
Fri Nov 03, 2006 6:24 pm
by steve wolverton
Jst83 wrote:I'm leaning towards a paint job.
*hugs Jst83*
Rasp &
Loader both have great suggestions. It can be done roll & tip method too. No need for air compressor, HVLP sprayers, etc.
The paint job is 90% bodywork. These are great suggestions if you want a near show quality paint job.
As for exterior latex, it works great too. I'm going to use it on my camper and I'm adding texture to it so won't need a flawless product to paint. You won't get the extreme gloss or showroom finish by using it, but if you're looking for a nice looking paint job, that's easily repairable, then by all means go for it!
Re: Paint seal
Posted:
Fri Nov 03, 2006 11:07 pm
by Jst83
steve wolverton wrote:As for exterior latex, it works great too. I'm going to use it on my camper and I'm adding texture to it so won't need a flawless product to paint. You won't get the extreme gloss or showroom finish by using it, but if you're looking for a nice looking paint job, that's easily repairable, then by all means go for it!
Do you plan to put a coat of anything over the paint for added protection or leave it as is?
What type of texture? I was thinking of that myself. Will the texture wear down with the wind from pulling it?
Scott
Re: Paint seal
Posted:
Fri Nov 03, 2006 11:18 pm
by steve wolverton
Jst83 wrote:Do you plan to put a coat of anything over the paint for added protection or leave it as is?
No coating, it will be left as is. The paint is the protection (UV inhibitor for the epoxy too), as exterior latex is just dried rubber.
Jst83 wrote:What type of texture? I was thinking of that myself. Will the texture wear down with the wind from pulling it?
Here's a link:
http://www.zinsser.com/product_detail.asp?ProductID=47
I think I'm going to try the medium texture.
As far as wind pulling at it, I'm not concerned with it. These products are often used in high-traffic non-skid settings (boats, stairways, etc.) where there is a lot more pounding than air resistance.
I'll keep you updated if you'd like - I should be painting mine in a week or so with the stuff.
Re: Paint seal
Posted:
Sat Nov 04, 2006 8:59 am
by Jst83
steve wolverton wrote:I'll keep you updated if you'd like - I should be painting mine in a week or so with the stuff.
Thanks I'll be looking foward to the outcome. I won't be able to paint till spring which is ok I still have lots to do before I think of painting. Just like planing ahead
Posted:
Sat Nov 04, 2006 9:33 am
by dwgriff1
The top of my tear is good quality exterior paint. I figure I can touch it up real easy any time it is necessary.
dave
Posted:
Sat Nov 04, 2006 10:08 am
by Jst83
dwgriff1 wrote:The top of my tear is good quality exterior paint. I figure I can touch it up real easy any time it is necessary.
dave
How did you apply your paint?
Posted:
Sat Nov 04, 2006 10:14 am
by doug hodder
I've used automotive clear and base/clear systems for top coating the tear...sprayed through a gravity feed HVLP gun...it's a lot more expensive, but I can wash and wax it like a car and it really shows off the wood underneath...Doug
Posted:
Sat Nov 04, 2006 12:37 pm
by Jst83
doug hodder wrote:I've used automotive clear and base/clear systems for top coating the tear...sprayed through a gravity feed HVLP gun...it's a lot more expensive, but I can wash and wax it like a car and it really shows off the wood underneath...Doug
Very Good, How well will that work over regular household Paint.
Posted:
Sat Nov 04, 2006 3:52 pm
by cracker39
I'd think that any good enamel paint would work, latex or oil. I chose oil based porch and deck enamel (glossy). What I didn't do is to seal well enough and I'm having problems because of that.
Paint if you want, it makes a nice finish...BUT...SEAL IT PROPERLY. At least 3 or 4 coats of exterior varnish, or better yet, use epoxy. I would even recommend putting 3"-4" glass tape on the edge joints and feathering the edges so that it is not so obvious. If I had to do it over again, I'd seal with epoxy and glass tape.
Originally, I sprayed on my primer and enamel finish. For redoing some parts, I used a short nap roller and it looks OK. I wouldn't try it with a brush though.
