mikeschn wrote:Roughing it up is a good plan. The more wood grain you can expose, the better your joint is going to be.
Another option, instead of using titebond III, is to use epoxy as a glue. Then you don't have to rough anything up.
kayakrguy wrote:Aunty M,
So you did this too?By respirator I hope you mean a dusk mask...the respirators cost a zillion
How did roughing it up work for you--were you able to get the roof tight to the walls?
I will be sealing the roof and the wall/roof seam with epoxy AFTER I put it on so I hope that the coatings of epoxy will also serve to bind the roof to the walls...
thanks,
Jim
So you did this too? By respirator I hope you mean a dusk mask...the respirators cost a zillion How did roughing it up work for you--were you able to get the roof tight to the walls?
