ballpark wrote:Thanks! I think the Benroy back end would work very well. I like many ideas from the lightweight model you designed also. I really think one of the main objectives of the teardrop is to be able to tow it with any vehicle.
I used SoildWorks 2006 to draw this up. This is a fairly simple model, hopefully after I get some detail drawn you can really see what the software can do.
mikeschn wrote:Kurt,
It's time for you to do another one. Take everything you learned over the past 5 years, and build a beaut.
Kurt (Indiana) wrote:Thanks for the Kick in the butt.
ballpark wrote:Kurt- I am not sure what a shape file is? Do you want something else? IGES? STEP? The models and assembly?
I like your design, do you have any better interior pictures? Maybe of the front section?
Gerdo wrote:Keep in mind that if you have a 16" overhang on the front, your tongue will probably be too short. As a general rule your tongue should be about half the width of the Tow Vehicle plus a few inches, minimum. This will keep your TV from hitting the TD body if you jacknife.
