by Kevin A » Sat Nov 11, 2006 10:22 pm
I heard that familiar snap too when installing the ceiling panel in my tear. I had mine set up so I didn't have to use any screws or nails to hold it in place, it was locked in place with a cleat fastened to the floor at the front of the trailer and another at the header support for the hatch hinge. While forcing the panel into place I pushed just a bit too hard along the edge near the very front of the trailer and SNAP,. The panel had already been stained and sealed so rather then start over, I opted to just add another spar across the front that supported the crack as I had not yet installed the outer plywood. Unless I pointed out the 3 inch long crack, you would never know it was there.
