NightCap wrote:I've looked through the forum and find myself still wondering what the best goop to put under the "Better-Than-Hurricane" Leak proof Galley Lid Hinge? it will be attached to wood and not aluminum. What Caulk will hold up longer in the sun snow and rain?
Miriam C. wrote:Hey Mike
How much of the Lextel did you need to do the hinge?
Jiminsav wrote:if it's under the hinge, and out of the sun, it don't matter what you use..it will last a long time..I used aluminum colored silicon caulk..looks good, lasts a long time.
mikeschn wrote:Is that a trick question?
I just put a generous bead under the hinge, and cleaned up the excess that squeezed out.
I probably squeezed the trigger a few times. So what is that? 1/16th of the tube? I used a full sized tube like this... and have plenty left over...Miriam C. wrote:Hey Mike
