Cold Weather Epoxy Question
Postby NightCap » Wed Nov 22, 2006 7:58 pm
I want to get out there and get the epoxy and glass on my seams but the weather is cold. Can I do epoxy in 40 to 50 degrees? Will it just take longer to harden? I want to get the protection on before the moisture in the air blows out all the layers of my plywood.
#1 - 100% Done #2 - 100% Done Thinking about #3
NightCap
Images: 259
Postby RAYVILLIAN » Wed Nov 22, 2006 8:03 pm
Nightcap
We just had a thread last week about winter epoxy. Raka makes a low temp hardener that works. I used it on the winter warrior two winters ago and it works down in the 40s.
Here's the thread
http://tnttt.com/viewtopic.php?t=12519
Good luck cold weather epoxy is doable.
Gary
111961Image
RAYVILLIAN
Images: 109
Postby NightCap » Wed Nov 22, 2006 8:50 pm
Yep, that is the info I needed. No more replies are needed. Thanks.
NightCap
Images: 259
