best HF trailer to use
Postby tncruiser » Tue Oct 19, 2004 3:21 pm
my wife and i have decided we WANT A TEAR DROP iwill build it my self i already have created my full size wall template i beleive i can handle the build but not sure which HF kit would work best also curios as to some of the final weights on trailers that other folks have built any help or sugestions will be greatly appreciated
thanx brian & ellie jhf trailer to use
if you don,t like my driving stay off the sidewalk
tncruiser
Images: 6
Postby Clancy Courtney » Tue Oct 19, 2004 3:44 pm
I used the 1800# capacity trailer. Its on sale for $299.99 in their retail stores.
http://www.harborfreight.com/cpi/ctaf/D ... mber=40597
The website has it for $349.99.
Good luck,
Clancy
Clancy Courtney
Images: 11
Postby Chip » Tue Oct 19, 2004 3:52 pm
Brian welcom to the board,,,not to give ya a bad answer,,but a lot depends on the size of the tear,,,length and width,,also kind of construction and how heavy or how extensive your cabinets are gonna be,,
some trailers are light weight,,in the 6-800 lbs and would work fine on a lighter trailer,,others are 11-1400lbs and need a heavier rated trailer to carry the load safley,,,also tongue weight can be a real issue if ya front load the tear and or have the axle located to far to the rear,,,Just ask Mike about his Baja,,with close to 200lb tongue weight,,I guess we need more info on size and your design ideas before a good answer can be given,,keep the info coming and take pictures,,,again welcome
what part of Tenn are you in,,there is a group of us getting together near Brevard, NC this weekend
chip
54"x9'4" tear
4'x8' tear
Chip
Images: 49
Postby Scooter » Thu Oct 21, 2004 1:01 pm
Where exactly is Brevard, somewhere in or near the Smokies?
The RoadCamper the old teardrop
Scooter
Images: 69
Postby Clancy Courtney » Thu Oct 21, 2004 1:18 pm
Scooter, Brevard is southeast of the Great Smokies Nat Park. Its east of Hendersonville and 32 miles southwest Asheville.
Clancy
Clancy Courtney
Images: 11
Postby mikeschn » Thu Oct 21, 2004 1:21 pm
In a poll of users here, the 1800# HF trailer won hands down. So to answer your question, the 1800# one!!! :o :shock: :lol:
Postby asianflava » Thu Oct 21, 2004 1:47 pm
Scooter wrote:Where exactly is Brevard, somewhere in or near the Smokies?
I thought BufordT would be the one asking this question.
asianflava
Postby nater104 » Mon Oct 25, 2004 11:10 pm
Doesn't the 1175# trailer have 12 inch wheels?
Nathan -~- In the Lehigh Valley, PA
1966 15' Scotty Gaucho
1973 Apache Ramada
2008 Jayco 19H
nater104
Postby Joseph » Tue Oct 26, 2004 5:27 am
I used the HF 990 lb. folding trailer with 4.8 x 12" wheels.
Joseph
Joseph
Teardrop Pirate
Postby darkroomsource » Thu Oct 28, 2004 12:12 pm
I used the 1175 # HF trailer, with 12" wheels.
I maybe should have used the heavier one, since my trailer ways in at 1060 pounds.
But then, with this suspension it does not bounce around at all on the road, and I understand that with a heavier suspension it probably would.
The frames are all the same, it's only the springs and axle that are different.
The hubs, too, are the same.
I plan on changing the rims, since there are 14" rims with the same lugnut configuration, but that's another project.
-- Andy Hughes
My Teardrop
Grace Happens
darkroomsource
Postby GeorgeT » Sun Oct 31, 2004 7:46 pm
The hubs, too, are the same.[/quote]
I believe the tongues are a bit different on the two HF trailers. The 1800 lb tongue U channels with a have a little 3/8 inch lip on it or "return" making it a bit stronger whereas the 1175 lb tongue has a plain U channel. However I think the 1175 has a cross member on the tongue that helps to strengthen it. I am thinking on using the 1175 trailer too. My estimate for my design comes in at 930 lbs fully loaded with a 10% allowance for things a I forgot. What I was wonderin' was that you said the hubs are the same. Did your 1175 trailer come with a 5 bolt hub and wheels. The HF website isn't clear on the 1175 trailer. Just says 12 inch wheels. Another site I saw describing the 1175 said it came with 4 bolt hubs and wheels. How long ago did you get your trailer? Thanks for any info! :)
Lookin' up in da skize with ize on da prize
http://home.earthlink.net/~g.teague/
GeorgeT
