by 48Rob » Mon Dec 25, 2006 6:42 pm
Hi,
Sounds like the surface wasn't properly cleaned/prepared for the stripe...
Latex CAN be used over oil.
Oil cannot be used over latex.
Latex is flexible/stretchy and can easily deal with the minor movement presented by an oil base.
When non flexible oil based paint is applied over latex, it cannot withstand the movement of the latex base, and thus fails.
All the stripe paint should be removed, then a degreaser/cleaner used to clean the oil base.
After cleaning, a suitable solvent and means to roughen the base will provide for good adhesion of the new stripe paint.
Were it mine, I would choose an oil base for the stripe, as latex will dull quickly and never withstand a polish or even a few good scrubbings without looking like something inexpensive was applied over the stronger base coat.
Rob
