Installation of roof spars
Postby sandman » Mon Jan 01, 2007 9:57 pm
Hey Gang,
I am finally getting into the start of my build since changing designs a few weeks ago. Is there a general rule about the best spacing for roof spars? I am using Steve's Cowper Plans but would like to install the roof spars uniform so I know where all the beams are. Some people say 8" center, 10" center, and so on. I plan on a roof vent and from what I understand, you have to frame this area 14 1/4" x 14 1/4"
sandman
Images: 154
Postby Kens » Mon Jan 01, 2007 10:15 pm
All I did was place one were the hatch goes the vent and the front window. Then spaced the rest were the ply seams went and curves. Not a big deal.
Good day every day!
Kens
Images: 26
Re: Installation of roof spars
Postby steve wolverton » Mon Jan 01, 2007 10:18 pm
sandman wrote:I am using Steve's Cowper Plans but would like to install the roof spars uniform so I know where all the beams are. Some people say 8" center, 10" center, and so on. I plan on a roof vent and from what I understand, you have to frame this area 14 1/4" x 14 1/4"
Building from the Cowper plans...cool! :thumbsup:
I'm trying to remember my spacing for that build.
Ok, I just looked at my plans and I didn't specify the distance, only evenly spaced. Hmm. I was thinking they were every 12", but I cannot remember.
�veni, vidi, vici.�
steve wolverton
Images: 11
Postby Ira » Tue Jan 02, 2007 8:33 am
Sandman, people have done it a million ways--and I don't think one has collapsed yet. 8" sounds awfully close together though. Like overkill. I think I did mine around 12".
One point about the framing for that vent though:
If you're using 1 by 2s for your roof spars, and you make your opening 14 1/4", make sure you add extra pieces of 1 by 2 all around the opening, so you'll have lumber to screw into. Otherwise, your screws will go into air when you screw into the screw openings of the vent's flange.
This is a BIGGIE to remember, because you install the vent after your roof and cabin ceiling are on--and once they're on, it's too late to add that extra framing.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby Tripmaker » Tue Jan 02, 2007 6:13 pm
My spars are about 14" apart except where the roof line curves and there they are about 9" to maintain a smooth curve. I agree with what others said about the fan opening. I glued poplar 1x2's together to frame out the opening. Look at the generic Benroy plans at the top of the forum for the measurements they recommend.
Jim
Tripmaker
Images: 59
Postby asianflava » Tue Jan 02, 2007 7:55 pm
I made mine 12" on center. Probably the only reason why was so that it would be easier to find them after I skinned over them.
asianflava
Postby steve wolverton » Tue Jan 02, 2007 9:35 pm
Mine are 18" to 24" apart, and I have a lot more camper exposed to the wind than most.
�veni, vidi, vici.�
steve wolverton
Images: 11
Postby Sonetpro » Tue Jan 02, 2007 9:43 pm
Mines 24" OC. But a few extra in the radius.
Sonetpro
Images: 107
Postby steve wolverton » Tue Jan 02, 2007 10:09 pm
Sonetpro wrote:Mines 24" OC. But a few extra in the radius.
How wide is that thing?
�veni, vidi, vici.�
steve wolverton
Images: 11
Postby Sonetpro » Wed Jan 03, 2007 8:23 am
63" wide x 12' long.
Sonetpro
Images: 107
Postby Denny Unfried » Wed Jan 03, 2007 8:40 am
The hatch hinge will attach to the last spar and you'll want to construct it to be very sturdy. I used a 2 X 3" piece of oak attached with glue and four screws on each end. This was the weakest part of most 40's teardrops and receives a lot of stress.
Denny
aka - "Uncle Denny"
<img src="http://www.uncledennyscorner.com/teardrop/photos/Linux.gif">
Denny Unfried
sprint car builder/racer & all that jazz
Postby Tripmaker » Wed Jan 03, 2007 12:37 pm
Sonetpro - You must have used a wide angle lens. That TD looks to be much more than 63" in the picture. Sure it's not 103" :lol: Maybe it's just the angle you took the picture at.
Jim
Tripmaker
Images: 59
Postby steve wolverton » Wed Jan 03, 2007 6:09 pm
Tripmaker wrote:Sonetpro - You must have used a wide angle lens. That TD looks to be much more than 63" in the picture. Sure it's not 103" :lol: Maybe it's just the angle you took the picture at.
I thought the same - looks like it's 8' wide!
�veni, vidi, vici.�
steve wolverton
Images: 11
