Slide out for the Cooler - Assistance
Dear Friends
I would like to install a slideout system for our cooler.
Even though the technical specs have nothing to do with the slides but here is our cooler. The Isotherm TB 32
TB 32 comes with injection moulded cabinet and a blow-moulded detachable lid. High-density insulation and an integrated evaporator, ensures food and drink are kept cooler for longer. An internal light is mounted. The TB 32 also incorporates an AC/DC converter as standard and its multi function electronic thermostat has an ECO function that keeps electrical consumption to a minimum. It has recessed hand-grips.
Type TB32
Volume (litres) 32
Dimensions
HxWxD (mm) 380x335x580
Weight (kg) 18
Power
Consumption (Amp)
Average/Max (12 V) 0.7/4.0
Danfoss Compressor Type BD35F
Freezer -10°C 32 or
USA specs - Specifications
TB32 - 8.45 gallons real capacity
Dimensions - WxHxD: 22.84 X 14.96 X 13.2 Inches
Danfoss Compressor BD35F
Voltage: AC/DC 110-240 V and 12/24 V
It will not fit in the length way.. only side.. and Id like for it to slide out.
the original accessorie is very expensive here ... meaning the slide out system... and its in my opinion no better than the slide brackets available at hardware stores...
Classic Finn
Type TB32
Volume (litres) 32
Dimensions
Weight (kg) 18
Power
Consumption (Amp)
Freezer -10°C 32 or
Classic Finn
