Page 1 of 1
A 5 Dollar Try
PostPosted: Sun Feb 04, 2007 2:32 pm
by Duck Daddy
I found this OSB (I think) at Home Depot for 4.96. a sheet.
Thought it would be good for a cheap practice run at my measuring and cutting
<a href="http://photobucket.com/" target="_blank"><img src="http://i78.photobucket.com/albums/j106/duckdaddy/Picture292-1.jpg" border="0" alt="Photobucket - Video and Image Hosting"></a>
Pleas be critical toward me. :)
I know its hard to tell from the pic, but does it look alright?
It sure helped make the project look right.
The floor looked small until I sat this thing on top.
<a href="http://photobucket.com/" target="_blank"><img src="http://i78.photobucket.com/albums/j106/duckdaddy/Picture288.jpg" border="0" alt="Photobucket - Video and Image Hosting"></a>
PostPosted: Sun Feb 04, 2007 2:52 pm
by rbeemer
DD,
The one good thing about using OSB is that now you will have a good template to use to router the inside and outside profiles from
How far up is the door opening from the bottom. I am thinking you might want it lower because your mattress wil compress and when you try to sit by the door your legs may not like it(no padding). Will your fenders be in the way of the door opening? How are you going to mount the back hatch cover? I I do not see a cutout for the hatch - not saying you have to, just something to think about.
Looks good though and if you are happy that is all that matters.
PostPosted: Sun Feb 04, 2007 3:07 pm
by Miriam C.
:applause: :thumbsup: Looks good to me. A practice pattern is a good idea. Lets you know if you need a change.
GitRdun. ;)
PostPosted: Sun Feb 11, 2007 9:44 am
by Duck Daddy
Great thoughts!!
I have put my efforts into finnishing the axle so I will know where to mount the door.
I also was worried about the door being too high.
I am confused about the cut out for the hatch.
I sure dont want to mees up a good sheet of plywood.
So Please help!! :)
PostPosted: Sun Feb 11, 2007 9:49 am
by toypusher
Duck Daddy wrote:I am confused about the cut out for the hatch.
Refer to page 20 of the 'Generic Benroy Plans' for the hatch cutout. At least I think that what you are talking about.
PostPosted: Sun Feb 11, 2007 9:51 am
by Miriam C.
Your hatch should meet your bulkhead wall. So the cutout will start there and follow around. This is deep enough to allow the hatch to fit level over the sides and have room for the weather stripping and Aluminum trim if you use it.
PostPosted: Sun Feb 11, 2007 11:44 am
by Duck Daddy
Hate to see what this thing would look like with out you guys.
:D
Cant believe I missed that on the plans.
Im also thinking of a square door.
I kinda need to keep it simple.
BUT IM READY TO CAMP!! :twisted:
PostPosted: Sun Feb 11, 2007 1:28 pm
by Geron
looks like you're doing the same as me. Sides attached directly to the sides of the floor. Gives and extra 1.5 inches inside.
Geron
