Dale M. wrote:MIG is absolutely easier to weld with also easiest to learn on... So easy a blond can learn to do it...
IF you can get 175 amp (220 volt) unit its to your advantage ..If that is to much get a 135amp (110 or 220volt ) unit... Lincoln and Miller are both excellent brands. Check both Lincoln and Miller manufactures web sites for some excellent information.
Also consider shield gas unit, it welds clean with absolutely no splatter, flux core will require some cleanup. Most MIG welder prefer shield gas units. Most people around my part of country prefer Miller.
Also look at controls. Both amperage and wire feed should be infinite adjust controls. Stepped controls ( Hobart and Harbor Freight) will usually be to hot or to cold for anything you are trying to weld...
IF you can't master it in a few hours, try local night school or junior college that has technical courses on welding....
Also harbor Freight units are cheaply constructed and getting replacement parts may be a problem.
Check prices on e-bay, some ebay sellers have some really good prices and FREE shipping to lower 48 states.
Dale
Dale M. wrote:The only thing I would continue to suggest is DO NOT get locked in to Home Depot... There are other vendors out there and they will discount if you handle them right.... Have you checked local industrial suppliers/welding shops?
Dale
Rebel wrote:This one is on sale at Northern Tools and a frend swears by them....but its still expensive at 649
http://www.northerntool.com/webapp/wcs/ ... allpartial
emiller wrote:Your right Gaston we with welders should help our trailer buddies. I have two Miller welders and a plasma cutter. I prefer the Miller brand and have used differnt ones. The Lincoln welder is fine for home welding.
