Sealing under Filon
Sealing under Filon
Postby agileaction » Wed Feb 28, 2007 12:54 pm
We are planning on skinning with Filon, but have a question. I can't seem to find the answer, but maybe I'm just not typing in the right search words...
If we skin in Filon, over 1/8" luan, do we need to seal the luan with epoxy, or some other sealer/hardener prior to skinning with the Filon?
agileaction
Postby BILLYL » Wed Feb 28, 2007 1:06 pm
I don't see why you would. But it couldn't hurt - IMO. But some else will chime in.
Have fun.
Good Luck
Bill
"If your children ever find out how lame you really are, they'll
gonna murder you in your sleep...." Frank Zappa
BILLYL
Postby agileaction » Wed Feb 28, 2007 1:09 pm
BILLYL wrote:I don't see why you would. But it couldn't hurt - IMO. But some else will chime in.
Have fun.
Good Luck
Bill
I'm thinking cost. I would like to do what's necessary, but not redundant, in the interest of costs, as well as weight, though I can't see where epoxy would add anything in terms of weight, it would add to the cost.
If it's necessary, then I want to do it.
Thanks for the feedback.
agileaction
Postby bobhenry » Wed Feb 28, 2007 1:25 pm
completely sealing only one side of laminated flat goods will generally cause them to expand and contract "out of sinc " with the other side of the sheet because of moisture. The wood fibers will swell on the un sealed side while they are protected on the other side from the moisture. Luan is a fairly moisture tolerant species but I know is will cause plywood to contort into all kinds of kinks and buldges. Your adhesive is generally applied with a notched trowl so even though you have covered the face of the fiber there remains small avenues to allow it to breath. I would also think that the adhesive would bond better to the wood itself because of the small pores present in all lumber. That's my 2 cents worth.
Postby agileaction » Wed Feb 28, 2007 1:39 pm
bobhenry wrote:completely sealing only one side of laminated flat goods will generally cause them to expand and contract "out of sinc " with the other side of the sheet because of moisture. The wood fibers will swell on the un sealed side while they are protected on the other side from the moisture. Luan is a fairly moisture tolerant species but I know is will cause plywood to contort into all kinds of kinks and buldges. Your adhesive is generally applied with a notched trowl so even though you have covered the face of the fiber there remains small avenues to allow it to breath. I would also think that the adhesive would bond better to the wood itself because of the small pores present in all lumber. That's my 2 cents worth.
A rep at the supplier where I'm getting my Filon has a spray adhesive that goes on both the Filon and the luan. It's much like the adhesive used to put laminate onto a countertop. Anyway, that's what I'm planning on using.
Any thoughts on that?
Leslie
agileaction
Postby bobhenry » Wed Feb 28, 2007 1:53 pm
sounds like an aerosol contact adhesive. ANYBODY HAVE PROBLEMS WITH LAMINATE OVER PLYWOOD USING CONTACT ADHESIVE ?? (they say that's how we shout on this forum) Maybe someone will hear us. I'd follow the directions and go for it ,just allow for the flash off time as they direct. It will take several minutes and will usually be dry but slightly tacky to the touch. It sticks where it lands so be sure you are lined up where you want to be there is generally no adjusting. :worship:
Postby glassice » Wed Feb 28, 2007 2:00 pm
The glue will work PUT CUT some PVC pipe to hold up in the air tell you have lined up and square then rool out
It is not the return ON my investment that I am concerned about; it is the return OF my investment
glassice
Postby josephhanson » Wed Feb 28, 2007 3:49 pm
I put filon on my trailer. I used 3m spray adhesive (it was all over everything, legs, glasses, hair, etc. The filon stuck great! I put all the trim pieces on siliconed under all the trim pieces, and everthing looked good. Then I moved the trailer out into the sun....the filon expands and contracts with the sun causing buckles and waves. It does stay in place though, I think the edge trim, window trim, and door trim are the actual filon holders. I would use filon again, but I would try and find a glue to be trowel on.
That's my experience with filon.
Joe
Joe
josephhanson
Images: 46
Postby bdosborn » Thu Mar 01, 2007 9:40 pm
bobhenry wrote:sounds like an aerosol contact adhesive. ANYBODY HAVE PROBLEMS WITH LAMINATE OVER PLYWOOD USING CONTACT ADHESIVE ?? (they say that's how we shout on this forum) Maybe someone will hear us. I'd follow the directions and go for it ,just allow for the flash off time as they direct. It will take several minutes and will usually be dry but slightly tacky to the touch. It sticks where it lands so be sure you are lined up where you want to be there is generally no adjusting. :worship:
I used contact cement with my Filon and it doesn't work as well as I would have liked. It delaminated the first time it sat in the sun. I would use the stuff at Home Depot specifically made for gluing Filon.
Images: 806
