Steel Tube Framing?
Steel Tube Framing?
Postby lonebird » Mon Mar 05, 2007 12:42 am
Almost all of my construction experience has been theater related. So, surprise surprise, when I started sketching teardrop ideas I found myself automatically dotting in 1” box steel framing. :lol:
Ya see, the materials I’m most comfortable building with are cheap cheap cheap scrap 1” box steel, masonite and MDF. Yet I haven’t seen any steel tubing used in framing on this site. I’m guessing there is a really good reason for this… I just dunno what it is. Do you? :oops: The steel tubing I’m used to using is 16 gauge box which weighs .06 lb per foot a little less then a 2x3.
The things that one most wants to do are the things that are probably most worth doing.
lonebird
Images: 6
Postby dhazard » Mon Mar 05, 2007 12:47 am
I was going to send you to the Trailer Tutorial link at the top of the page, but it’s not working… :x
Many miles and many tears. Times were hard but now they're changing.
You should know that I'm not afraid.
dhazard
Images: 122
Postby madjack » Mon Mar 05, 2007 12:51 am
...once again...keep on looking...the majority of custom steel frames built on this board are from 2" square tube in various gauges...I have moved to 2x1x3/16 "c" channel becuse of the cost of square tube...in the trailer tutorial in the top index, Doug used 2x2x16ga tube for his frame...keep in mind that you do not need to build a frame as heavy as a utility trailer is built since the TD, if properly constructed, forms a "torsion box" and is rigid unto itself...all the steel frame is needed for, is to tie the axle to the tongue and give a place to bolt the body to...there have also been several who have built frameless......
Postby madjack » Mon Mar 05, 2007 12:52 am
Dan, I guess we will haveta lookintothat.......... 8)
Postby lonebird » Mon Mar 05, 2007 12:53 am
Sorry guys, guess I didn't do my homework. I'll keep readin'
lonebird
Images: 6
Postby madjack » Mon Mar 05, 2007 1:00 am
Doanworryboutit...steel in many forms and dimensions have been used successfully...and like I said, some used no steel at all and some use steel even for sidewall framing...the beauty of these little trailers is the fact that they can be built many different way and made to reflect the builders skill and imagination....
Postby Miriam C. » Mon Mar 05, 2007 1:16 am
:o Well it is late but are you wanting to make the trailer frame out of steel tubing or the teardrop frame itself?
Postby Kevin A » Mon Mar 05, 2007 1:29 am
Miriam C. wrote::o Well it is late but are you wanting to make the trailer frame out of steel tubing or the teardrop frame itself?
Ya know, Miriam, I think you are right. I just read Lonebird's post and I too think she was talking about the teardrop body rather than the frame itself. I can think of several trailers that were framed in steel rather then wood. The 5 wide guys from just south of here built some really nice trailers with steel framing. Here's the link.
http://saber.net/~sking/teardrop.htm
Kevin A
The other guy
Images: 289
Postby Big DE » Mon Mar 05, 2007 1:13 pm
LoneBird I'm using 1 x 1 square tubing for my tear drop look at my album I will be adding more photos later today
BigDe :thumbsup:
Big DE
Images: 93
Postby lonebird » Mon Mar 05, 2007 1:55 pm
Big D, Kevin A thank you sooo much, those photos were exactly what I was looking for! I can continue my fabrication with a lil more confidence now... I'll just eventualy have to find a shop that's willing to let me play with their toys... :worship:
lonebird
Images: 6
Postby Keith » Wed Mar 07, 2007 10:40 am
Hi Lonebird,
We've built five trailers based on the Modernistic trailer using steel frame. Currently John is starting a sixth one that will be twelve feet long and five and a half feet long using a round tube for the corners. He made a test panel like the radius at the rear of the trailers and it looked great. We'll just have to see how it turns out. We'll be taking lots of pictures and posting them up as he goes.
I recently changed my internet service provider so I don't have access to the web page that you looked at. The email address listed on there is no longer active. If you have any questions feel free to contact me at the address on my profile. I'll have to transfer our old web page to my new host one of these days.
Here is a link to our photos.
http://new.photos.yahoo.com/[email protected]/albums
Keith
Keith
Images: 5
