Doors designed before or after build
Postby Ron Dickey » Thu Mar 08, 2007 4:02 pm
This is the slowist I ever saw this site come up. and I can't sit for long just got a prostate byopsy and sitting aint fun.
every thing gets in the way of my build ....
Qestion doors do I do them last .... it is beginning to all come to gether on paper and in my mind .... next step is design doors and I am lost there.
back ones no problem side ones I am lost. no pixs still working on that
Can't sit any longer you know that you getting old when it comes to the prostate.
Ron
173882......173887
Ron Dickey
Images: 787
Postby toypusher » Thu Mar 08, 2007 4:05 pm
Ron,
Have you checked the Generic Benroy Plans, it has a section on building doors.
toypusher
Images: 324
Postby Ron Dickey » Fri Mar 09, 2007 3:21 pm
thanks Kerry that answered a lot of qestions I had not taken the time to look at that Mike should be designing spacerocket.
My wonder was the wall will have an outside wall and an inside wall with insolation for those cold mornings when I get up to 5000 feet.
The wall will be 1 and 1/4 inches thick or so. should the door also cover that distance are they made the same as the walls. with a air pocket in the middle to keep out mr. cold.
I will try and draw it and scan it in and see if I can come up to the next step of getting such in other wise as I continue to lean how to get photo's into system I will shoot it and send it.
I never thought that in so leaning how to build a trailer I would in ensence learn to send photo's on the net. I am the old fastioned type photographer using film this digital stuff I new would catch up to me but never new how far it would take me. I love to learn.
I am feeling better today. I had to stand for several hours siting was the pits.
Ron
173882......173887
Ron Dickey
Images: 787
Postby toypusher » Fri Mar 09, 2007 3:44 pm
Ron,
You should build the doors the same thickness of your sidewalls. Take a look at my "Build and Camping Photos" in my signature and you might be able to see how I built mine. There are from the Cubby plans.
toypusher
Images: 324
Postby Ron Dickey » Fri Mar 09, 2007 11:42 pm
Kerry,
Am I seeing you used plywood cut out for your middle frame between the two walls.
I was thinking of using the same wood as I would use to make the ark at the front arch of the trailer roof support. 1/2 x 1 s or something like that. I look at lumber every day the sizes have not sunk in.
I work at Home Depot. Almost everything I need is there but I buy alot of my stuff from local mom and pop lumber or hardware stores instead to keep my money in the local economy.
Any way thanks for the ideas and the help.
Ron
173882......173887
Ron Dickey
Images: 787
Postby toypusher » Sat Mar 10, 2007 5:43 am
Ron,
My construction is all 3/8" plywood on the outside, 3/4" framing, and 1/8" inside skin. I used the plywood because it was convienient for that part of the door construction.
toypusher
Images: 324
