Classic Finn
madjack wrote:Heikki, glue used is upto you...whatever you are familiar with and works in your weather will probably be just fine...Gorilla Glue is a 1 part, moisture activated urethane adhesive...I really like urethane adhesives whether they are GG or tube urethane constuction adhesives...SIKA makes many excellent adhesives as well.....
madjack wrote:...the right hand portion of the hinge as shown in your pic goes on the body...the left hand on the hatch...the long downleg on the left is for attaching to the tear hatch...we also drilled some additional holes in the top leg(on left portion) for more mounting strength...the hinge should be at least 1" longer(or more) than the body is wide...this will allow the hinge to act as a diverter...the hatch portion should be around a 1/2" shorter than the body portion...you then drill a small hole at each end of the hinge "barrel" portion on the body side and insert a small screw to keep the hinge from sliding around
madjack wrote:...correct me if I am wrong...the cabin side is finished...right...so you can do your permanent installation of the hinge on the body side...if you do it our way, the hinge will be temporarily installed on the hatch side...we used spacers the thickness of the hatch skin plus the AL that will cover the ply...once hatch is wedged into position on the tear, you will remove the spacers from under the hinge...you should now be able to slide the ply skin under the hinge and continue on with attachment of the skin...I would dry fit everything before appling adhesive...once the adhesive is setup, remove the hatch from the body, you can now remove the hinge from the hatch to apply the AL skin......
Jiminsav wrote:Heikki, I'm sure MadJack would be more then willing to hop a flight to Finland and get that hatch together for you..all it takes is a plane ticket.
