Thank You Madjack
We are so pleased so far since all is square the way its supposed to be...
feeling is still sort of jittery now that it comes time to add the hinge and get that aligned... We,ll do by your instructions....
Im just wondering as to what glue would settle in weather change like this....
Gorilla Glue doesnt seem to be found here unless its under a different name...
We have strong all weather glues but they need the gun as in silicone tubes....Would that be ok? Also we have this ... dont know if its familiar to anyone here..CASCOLIT
and Sikaflex (very popular here) 11fc Multipurpose Adhesive Sealant Black 310ml Sikaflex has multiple products available here but this is just one of the many...
Multipurpose elastic sealent and bonding adhesive
for waterproofing , sealing , roofing , sanitary ware Etc.
Seals, Bonds and adheres to a wide range of substrates
including:
Steel , PVC , Zinc , Fibre Cement , Aluminium ,
Marble , Clay , Concrete , Brick , Wood etc
Fast Curing and permanently Elastic. Resistant to shock , vibration and temperature change.
Here is the hinge we have ... also we have another one that we were thinking of at 1st but its a tough nylon or sort...
Is there a reason as to the Hinges sections being longer than the other? we also know that the hinge should extend beyond the exterior wall a bit,
was it an inch on both sides or less?
Classic Finn
