I found a trailer frame but,
Postby Airspeed » Sun Mar 11, 2007 1:37 pm
I found this trailer for $100,it has been in a fire, The owner replaced the bearings ,rims and tires. The frame looks like it got pretty hot at the top but the lower frame stills has paint on it so I dont think the heat did much damage to the steel, The one prob I see is there is no suspension. The axel is bolted right to the frame. I was hoping to spend no more than $100 on the trailer for my TD , I would like to use the existing axel and hubs as they are in great shape. Can anyone recomend what type of suspension I could use on this? Thanks! Aaron
[/url]<a href="http://photobucket.com" target="_blank"><img src="http://img.photobucket.com/albums/v655/aaronhero/trailor1.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
Airspeed
Images: 16
Postby Nitetimes » Sun Mar 11, 2007 2:06 pm
You'll be wasting a pile of money I'm afraid. I don't see anything really useable on there. Unless you figure those tires and wheels are worth a $100.
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby Nitetimes » Sun Mar 11, 2007 2:08 pm
Wooops, I missed that. Is that the spare on front? If so that is a 5-6k axle and it has 14.5" wheels with star hubs on it. Basically a house trailer axle.
RUN!!! Nothing on there you need!!!!!
Rich
Nitetimes
7000 Club
7000 Club
Images: 194
Postby Airspeed » Sun Mar 11, 2007 2:33 pm
What would be wrong with it,I mean why wouldnt it work? I would like to get chrome rims for it later,are they not available for that type of hub? What problems would I encounter? Thank you very much, Aaron
Airspeed
Images: 16
Postby madjack » Sun Mar 11, 2007 2:37 pm
I agree with Rich...keep on looking...a brand new 2000# axle w/hubs can be had for under a 100bucks...I am not a fan of rehabing an old axle/frame as often the rehab will cost you as much or more than going new...mobile home axles with that style of wheel are notorious for alignment and other problems...
http://etrailerpart.com/2ktrailerAxle.htm
http://abctrailerparts.com/2kaxles.html
...you should be able to find them locally as well......
Postby Keith B » Sun Mar 11, 2007 7:02 pm
For what it's worth.. I have $90 in steel, $161 in an axle, $200 in tires and rims, $60 in stabalizer jacks, $20 in a swing away tounge jack, $20 in lights and $15 in wire and 1.5 days of my time....if you can rebuild a trailer you can certainly "build" a trailer.. and get exactly what you want.... oh, and I've been told I overbuilt so you could probably cut that steel cost down :lol: . Good luck on your project. :thumbsup:
Keith
"Work and work and do your best! Paint and putty will do the rest!"
Keith B
Postby Airspeed » Sun Mar 11, 2007 7:34 pm
I have considered building one,I have a MIG welder metel cutting bandsaw
torch and all but I have seen so many trailers for around a hundred bucks Ill probably buy one,
I actually did buy a Harbor Freight trailer for $75 but when I went to pick it up the guy had sold it to someone else for $100 and then tried to give me money back in payments!
Thanks! Aaron
Airspeed
Images: 16
Postby Sonetpro » Sun Mar 11, 2007 8:22 pm
Aaron,
I used a boat trailer. I gave $125 for it.
Sonetpro
Images: 107
Postby Airspeed » Sun Mar 11, 2007 8:46 pm
Thats what Im looking for. I actually have one but it's under my old Dorsett boat, I am getting tempted! Aaron
Airspeed
Images: 16
Postby Miriam C. » Sun Mar 11, 2007 11:05 pm
By the time you buy springs at about $80 a set is what I price and the hardware to install them you are close to the price of a Harbor Freight. Thats when you weld your self. I have a used frame from a pop up and getting it right was a PITA.
Postby Gage » Sun Mar 11, 2007 11:26 pm
Miriam C. wrote:<snip>
:o
Image Image Image
Gage
Images: 28
Postby Miriam C. » Sun Mar 11, 2007 11:37 pm
:o
What??? Don't you remember the twist and the tires and .....Oh yeah and the rust I removed 3 times. :lol:
Postby doug hodder » Mon Mar 12, 2007 12:22 am
Airspeed...any iron that has been that close to or in a fire is a no no...a lot of the strength may be gone...some paint is still on it...might be OK...but I'm sure there are other options out there rather than taking a chance.......I saw a guy build a wood splitter with an I beam that was in a fire...It was a lot of fun to watch split wood...at least the first and only time, kinda cool to see a piece of I beam bend like that in slow motion...Doug
Postby Mark72 » Thu Mar 15, 2007 6:39 pm
Airspeed,
I have to agree with most others on this, I used an old camper frame to build my frame. While it turned out to be a pretty good frame and axle the extra work involved was a huge setback on build time for me. The worst part is the axle may end up playing too large a role in deciding what size td or ttt to build. My axle limited me to a full size mattress because of the width, while that dosn't sound like a bad size you must consider that due to being over 48" wide it is effectivly costing me the same as it would have to built a 60" wide tear.
Mark :thumbdown:
Mark72
Images: 127
