Aluminum vs Steel trailers.......
Postby wolfix » Wed Mar 14, 2007 8:26 pm
Last night several of us got into a discussion about a what we wanted to use for our TD trailer. I made the statement if I could afford it, I'm going with aluminum. Weight was my main reasoning, but being rust free is important too. I was the only person that would go with aluminim.......
Pro's and con's of each?? You guys seem to have many different perspectives on this.........
The trailer will be a 5x8 built with average weight walls.....
"I am the guy our parents warned us about."
wolfix
Postby Leon » Wed Mar 14, 2007 9:27 pm
If you aren't going to save weight elsewhere, the savings from the chassis will be small. Also, unless you are proficient at welding it, it can be more expensive to have it built (in addition to the cost of the materials). Aluminum is about 3 times more expensive than steel, and to build a similar strength structure it has to be about 50% heavier (in material not weight) than steel. In other words, an 1/8" steel tube is aproximately equivelant to a 3/16" aluminum tube. Where manufacturers make up some difference is less tonage to form the aluminum, and weight savings when the majority of the vehicle is aluminum. For a one-off trailer, there is marginal benefit.
Leon
Images: 21
Postby doug hodder » Wed Mar 14, 2007 9:46 pm
I had the same conversation with Andrew about a year ago...his reply...see Leons post. Doug
Postby wolfix » Wed Mar 14, 2007 9:50 pm
doug hodder wrote:I had the same conversation with Andrew about a year ago...his reply...see Leons post. Doug
Leon told me all I need to know.
Thanks
wolfix
