Link
Anyone use 1 of these as a "master" cutoff switch? I always thought that the "hot" (+) lead should be the 1 that's disconnected, not the (-) side.
jim wrote:nissem,
I dont think that is what they are talking about... this is a manual cut off to physically disconnect power at the source... like a blade disconnect...
the item you describe is an electonic device...
For more info on these units I would suggest you look to some of the stuff that they are using in the "green power" setups. they are used quite alot in the solar electric field. I have even seen plans on building one of your own at www.homepower.com
the link direct to the article is
http://www.homepower.com/files/lvdhp60.pdf
They are efective, just remember that to run the electronic device you are also spending a small amount of your energy.
mikeschn wrote:I just saw a picture of a blade disconnect. Was that yours Joseph R?
Can you display that picture in a message here?
