--------------Three materials for top and sides of teardrop.
Postby teardropsleeper » Thu Mar 15, 2007 9:25 am
teardropsleeper
Postby Keith B » Thu Mar 15, 2007 9:41 am
Hey, good find on the material... the EPDM rubber is tricky... I helped put a new rubber roof on a motorhome and it's easy to do..but it is NOT hiding...if your surface isn't perfect you will see every little dimple, etc. under it..however, on the top of a motorhome you don't really care :lol: unless you're 12' tall.
Keith
"Work and work and do your best! Paint and putty will do the rest!"
Keith B
Postby Ira » Thu Mar 15, 2007 10:02 am
That Filon is not all that cheap, but can you use it for the roof?
It's 102" high and comes in 5-foot lengths, so that'll handle a 4 by 8's flat sides without any problems or seaming.
But for the roof, you would have to roll it out the other way, so will it BEND that way?
Know what I mean? And no, I'm completely sober right now
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby toypusher » Thu Mar 15, 2007 10:27 am
That aluminum seems like a really good deal!!
toypusher
Images: 324
Postby Kit76 » Thu Mar 15, 2007 10:45 am
That Aluminum is a Good Find, and a Good Price. The Only thing is shipping is High!! :o
Chris
Don't Sweat the Petty Things, Don't Pet the Sweaty Things
Kit76
Images: 60
Postby Sierrajack » Thu Mar 15, 2007 5:48 pm
Good info!!!! Found some products on their site that's pretty cheap to use on the TD. :applause:
Sierrajack
Images: 41
Postby Nitetimes » Fri Mar 16, 2007 12:07 am
Ira wrote: And no, I'm completely sober right now
You seem to say that a lot lately. What's wrong??? 8) :lol: :lol:
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby Ira » Fri Mar 16, 2007 8:18 am
I only say that when I post before lunch on a weekday.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby teardropsleeper » Fri Mar 16, 2007 12:34 pm
Another good teardrop material. This might be the best one yet. Click on Foamkore
http://www.interiorproducts.com/installation.html
<img src="http://i67.photobucket.com/albums/h296/impalaman63/FK-Edge-LumberBand.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket">
teardropsleeper
Postby teardropsleeper » Fri Mar 16, 2007 1:05 pm
Just called on the price of the Foamkore.
1/8"Lauan Plywood - foam - 1/8" lauan plywood ---total 3/4" thick.
24 lbs per 4x8 sheet
Price = $100.13
1/8"Poplar Plywood -foam- 1/8"Poplar Plywood ---total 3/4"thick
20 lbs per 4x8 sheet
Price =$115.13
Not to bad a price considering you have the walls all done inside and outside.
teardropsleeper
Postby Ira » Fri Mar 16, 2007 2:00 pm
But you gotta forget about running any wires, unless there's a way to snake them through the foam.
Also, how do your spars connect? You're not gonna want to connect them to the interior side of that panel.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby asianflava » Fri Mar 16, 2007 3:38 pm
It has the same problems as any of the other prefab sandwich panels. The edges aren't closed out, and there aren't stringers installed where your bulkheads, cabinetry attach.
asianflava
Postby toypusher » Fri Mar 16, 2007 4:31 pm
asianflava wrote:It has the same problems as any of the other prefab sandwich panels. The edges aren't closed out, and there aren't stringers installed where your bulkheads, cabinetry attach.
I think that it would be workable, but probably more pain than worth. You could cut dados into the sandwich panel to install bulkheads and spars. Glue and then 'toenail' some finish head screws in to hold it. I think that Steve F. uses this method to install bulkheads in his tears.
toypusher
Images: 324
