Micro469 wrote:I used what ever I had laying around... you know---old door frames. molding,cutoffs, recycled framing lumber.......
doug hodder wrote:Gene...at the risk of starting some disagreement...seeings how you are in SC...and there are lots of furniture manufacturers in that part of the country...another option may be poplar...it's really straight even grained, light weight and easy to work, and takes just about any fastener without splitting, and can be painted easily if you want...It is used a lot in furniture manufacturing...If sealed well, I wouldn't think that any deterioration of it in the future would be a problem...I use it for interior cleats, ceiling ribs etc, but it doesn't finish up pretty if you want natural wood.... I guess it's also one of those things, depending on what part of the country you live in, what is the best deal for your buck. Just a thought...a bit late however, but info for maybe interior workingsDoug
GeneH wrote:After a long "Off" period I have finished sanding the profile for my tear to shape and am ready to start building the wall frames using the method Steve Frederick has in his CD.
With that in mind I went looking for the pine boards I need for the frame and found several types including, Eastern Pine, SYP (Southern Yellow Pine I think) which is considerably heavier and seems stronger than the Eastern pine, and whatever they are calling Whitewood which seems to be the lightest weight of all.
Not being an experienced carpenter I'd appreciate hearing what wood those of you that have built using this type of wall construction used.
BTW, the tear will be a Modernistic model that is 11 feet long and the side wall is 54 inches tall.
TNX...Gene
