by Roddy Riggs » Tue Mar 20, 2007 8:58 pm
Help somebody: I bought 040 aluminum for my tear, because it was the width I needed and the price was right. Now, I am about to put on the sides and here is the problem. This stuff is very hard to cut. If I glue it onto the side how do you guys trim it off flush? If I cut it to fit first, I still have to leave it a little large to trim down flush. Some have recommended using a router with a speed control. That didn't work for me. When I used it under full speed, I smoked the bit!..I was thinking of using an air nibbler which leaves about 3/16" above the top and then taking a die grinder and try to smooth it out. What do you think. Any suggestions welcome. thanks, Rod
I've been to three county fairs and a goat roping, but I ain't never seen anything like this!
