Question about Desert Teardrop Hatch
Postby Signman » Sun Mar 25, 2007 7:40 pm
Hello people, I have the Desert Teardrop plans. I am having a little diffuculty understanding the hatch plans. Especially the part about sealing the hatch. Do the sidewalls need to be trimmed in the hatch area to allow for weather stripping, or, what exactly is going on there? Sorry, but the plans are a little vague for a moron like myself. Any help would be greatly appreciated.
Thanks,
Darrel
Signman
Images: 30
Postby madjack » Sun Mar 25, 2007 10:23 pm
Darrel, I can't address the D/T plans directly BUT normally the sidewall is notched to accommodate the seal and any trim you may have...somewhere in the neighborhood of 3/8th of an inch but this will vary according to what trim/seal you use so you will have to figure the final number for yourself......
Postby Signman » Mon Mar 26, 2007 7:48 pm
Thanks Madjack, I'm hoping I can do that somehow with a router. The cuts that I made with my sabre saw were not that good. The blade seemed to wander quite a bit. Thanks for the info.
Darrel
Signman
Images: 30
Postby madjack » Mon Mar 26, 2007 7:50 pm
Sm, the best way to doit with a router onnan already built wall is to use a daddo bit to make the first cut and then a bearing bit to finish it out.........
Postby Sierrajack » Mon Mar 26, 2007 8:19 pm
I would highly recommend that you take the Desert plans and use them to line your birdcage. The Generic Benroy Plans and asking questions will usually get you out of trouble and headed in the correct direction.
:picklejuice:
Sierrajack
Images: 41
Postby Signman » Mon Mar 26, 2007 8:35 pm
Sierrajack, I agree with you 100%.
Signman
Images: 30
Postby Signman » Mon Mar 26, 2007 8:40 pm
Thanks again Madjack. I will try that.
Darrel
Signman
Images: 30
Postby fornesto » Tue Mar 27, 2007 10:13 am
Sierrajack wrote:I would highly recommend that you take the Desert plans and use them to line your birdcage. The Generic Benroy Plans and asking questions will usually get you out of trouble and headed in the correct direction.
:picklejuice:
ditto
fornesto
Postby Signman » Tue Mar 27, 2007 11:42 am
I'm glad it's not just me that thinks those plans are not the greatest. I was beginning to wonder if I was a complete idiot.
Signman
Images: 30
Postby Leon » Tue Mar 27, 2007 2:59 pm
I had a set of those plans and lost them years ago.....
No great loss
Leon
Images: 21
Hatch on desert teardrop
Postby Aaron Coffee » Tue Mar 27, 2007 7:01 pm
I used desert teardrop plans, my hatch sits within the walls and the skin is the same width as the body(extends beyond the ribs of the hatch)I have waether seal mounted on the lip that is formed from the over lap. Hope that helps. Will try to get pics tomorrow.
After having seen what is available for free and just by asking on this forum, I see how lacking desert teardrop plans are.
Aaron Coffee
Images: 26
Postby Signman » Wed Mar 28, 2007 5:21 am
Aaron, Thanks. Did you have to notch the plywood sides for the weather seal?
Thanks,
Darrel
Signman
Images: 30
DT hatch
Postby Aaron Coffee » Thu Mar 29, 2007 5:16 pm
No, i didn't notch the wall for seal clearance, If I get off of work early tomorrow will try to get some pics.
Aaron
Aaron Coffee
Images: 26
Postby Denny Unfried » Thu Mar 29, 2007 5:34 pm
If you can find one of the old style hurricane hinges with 1/4" offset you don't need to notch the sides but I don't think anyone handles them anymore. Another option would be to use the new style hinge along with a spacer between it and the roof which would eliminate the need for notching. You can find flat aluminum stock of various thicknesses at most home centers.
aka - "Uncle Denny"
<img src="http://www.uncledennyscorner.com/teardrop/photos/Linux.gif">
Denny Unfried
sprint car builder/racer & all that jazz
Postby Signman » Thu Mar 29, 2007 9:03 pm
Denny, Thanks for writing. I just bought my hurricane hinge yesterday, and it has the offset. At the time that I ordered it, I wasn't even aware that I would be able to do away with notching the sidewalls. Thanks for helping. Darrel
Signman
Images: 30
