Cutting Out The Wall The Easy Way
Not being the best carpenter in the area, I found a simple, accurate, not too expensive method of geting the walls cut out perfectly. It's called the MULTICAM 3000. It is a computer controlled router table which can utilize multiple sizes of router bits in any design you can get programmed. I took the information from the Widget to a local wood shop and he programmed the radius measurements and curves into the computer, made some of the changes I wanted which can include window cutouts, doors, setbacks for the hatch, ect. He then placed a sheet of 3/4" plywood on the cutting table which is covered with OSB which holds the plywood in position by suction. He then fed the info into the machine and like magic, it cut out all the pieces perfectly and accurately (as accurate as he had input the data). Cost me less than $150.00. Same kind of machinge as they use to make signs and pictures in wood. Check with some of the local wood shops in your area if you're not as confident in your cutting abilities. I figured I'd have spend that much in replacement plywood.
Jim[/b]
