toypusher wrote:Mary,
I would forgo the staples on the top skin use straping from the front to back (or vice versa). put one on each edge and a couple or three more in between. I don't think that you will need to pull any staples unless they are sticking up and you can not get them down.
Yes, actually the glue should hold everything for you. Don't use extra fasteners that you don't need. Especially, if you a putting trim on the edge anyway. The trim will hold your top skin in place. Most aluminum skins are glued minimally or not at all and held in place by the trim along the edge of the sidewall and roof line.
Classic Finn wrote:I,ll be buttoning up the Voyager this Easter Weekend... with the 1st layer of Marine Ply also.....Finally![]()
weather permitting...
Wife has the camera with her for Easter sooooooo.. No Pics till next week..![]()
By the way....4got... After installing the 1st layer... is there a need for any Marine Clear there? Another Layer will be applied .. And its high quality Marine Finnish Ply...?
Classic Finn
Mary K wrote:Classic Finn wrote:I,ll be buttoning up the Voyager this Easter Weekend... with the 1st layer of Marine Ply also.....Finally![]()
Classic Finn
Hello Heikki, Are you installing 1 layer of wood then aluminum?
Mk
Classic Finn wrote:Hi Mary... Yupper 1st layer it be... of Marine and then 2nd Layer of Marine..Then the Aluminum or Stainless.. I now have both, nicely bendable... After a long search, and negotiating with a place that normally dont sell to private individuals..ssoooooooooo I feel lucky.
Heikki
b.bodemer wrote:MK,
A girl can never have enough straps for this step!
One of the biggest things I've learned is even if you think you have enough............you don't. Have an extra strap or two and wood on had so you don't need to scramble like I did once I started.
Barb
Mary K wrote:Classic Finn wrote:Hi Mary... Yupper 1st layer it be... of Marine and then 2nd Layer of Marine..Then the Aluminum or Stainless.. I now have both, nicely bendable... After a long search, and negotiating with a place that normally dont sell to private individuals..ssoooooooooo I feel lucky.
Heikki
Heikki, I would think that you would not want to varnish (marine clear) on the first layer. The glue for the second layer would not stick to it.
I Don't know about on the second layer. Depends if you are floating the aluminum or gluing.
Mk
