fresh air,
fresh air,
Postby Airspeed » Thu Apr 05, 2007 11:32 pm
I am getting closer everyday to finishing my tear and now I am wondering if anyone has ever suffocated in one of these? I can see that
mine is going to be pretty air tight and was wondering if it wouldnt be a bad idea to install some type of alarm just in case of high Co2 levels or if all the vents and windows are left closed while sleeping or am I worrying about nothing? Thanks ! Aaron
Airspeed
Images: 16
Postby Miriam C. » Thu Apr 05, 2007 11:35 pm
You have very good instincts. You should always keep a window cracked and a sensor is a good idea. No sense in making the Darwin Awards. 8)
Postby doug hodder » Thu Apr 05, 2007 11:46 pm
By all means...leave some sort of ventilation open....in that confined space, you'll find that the outgassing from a foam mattress or even the finish after a year will still be evident....think smart!!! Doug
Postby Airspeed » Thu Apr 05, 2007 11:48 pm
Do any of you install a vent that cant be closed just in case one forgets to open one? I am thinking of one of those small round louvered vents that would let some ventilation just in case. maybe one near the ceilng and one near the floor.With my luck I would forget to open a vent before passing out. (camping is about the only time I drink) Thanks! Aaron
Airspeed
Images: 16
Postby Miriam C. » Fri Apr 06, 2007 12:14 am
Airspeed wrote:Do any of you install a vent that cant be closed just in case one forgets to open one? I am thinking of one of those small round louvered vents that would let some ventilation just in case. maybe one near the ceilng and one near the floor.With my luck I would forget to open a vent before passing out. (camping is about the only time I drink) Thanks! Aaron
:lol: I would definitely put in a permanent vent for that. Get two things your not used to doing and you just might be in trouble.
Joanne put some small vents using the cap type covers used on boats. They look good. You need something that won't let water pour in if it rains really hard.
Postby doug hodder » Fri Apr 06, 2007 1:11 am
How about cracking a window, before you crack a cool one? Doug :thinking:
Postby Jiminsav » Fri Apr 06, 2007 6:34 am
you could drill holes in the box like kids do for fire flies... :D
Jim in Savannah
Jiminsav
Images: 40
Postby WarPony » Fri Apr 06, 2007 7:03 am
Aaron, I don't think the carbon monoxide detectors will work for carbon dioxide. I'd just pop the roof vent open when you get to your camping spot.
Jeff
WarPony
Images: 289
Postby toypusher » Fri Apr 06, 2007 8:15 am
WarPony wrote:Aaron, I don't think the carbon monoxide detectors will work for carbon dioxide. I'd just pop the roof vent open when you get to your camping spot.
Jeff
That's what we do. the roof vent is always open at least a little bit. Usually one or both of the side windows are cracked open some too.
toypusher
Images: 324
