Page 1 of 2
Sealing Up Window, Vent Fan, Hurricane Hinge, etc...
Posted:
Mon Apr 09, 2007 1:09 pm
by Keith B
Hope to paint the TD this coming weekend and set the "goodies" the following weekend. Just like to see what everyones thoughts were on sealing windows, Fantistic Fan, door jams, galley hinge, etc....
1.) using putty tape?
2.) use Geocel or NP1 type sealant?
3.) combination of 1 and 2?
Posted:
Mon Apr 09, 2007 1:13 pm
by Steve Frederick
Putty Tape!
Posted:
Mon Apr 09, 2007 1:19 pm
by Geron
Putty tape.
g
Posted:
Mon Apr 09, 2007 1:21 pm
by Geron
Posted:
Mon Apr 09, 2007 1:46 pm
by Steve Frederick
Especially when you step on it and track into the house!
Posted:
Mon Apr 09, 2007 2:04 pm
by madjack
EVIL BLACK STUFF...aka auto windshield sealant/adhesive..........................
Posted:
Mon Apr 09, 2007 2:06 pm
by critter
Hey Guys,
Where do you get putty tape?
Posted:
Mon Apr 09, 2007 2:07 pm
by Geron
madjack wrote:EVIL BLACK STUFF...aka auto windshield sealant/adhesive..........................
How difficult is it to take something out that has been sealed with EBS?
g
Posted:
Mon Apr 09, 2007 2:12 pm
by Geron
critter wrote:Hey Guys,
Most any RV store will have putty tape. Haven't found it in the Box Stores -yet. Comes in a roll about 4.50 a roll. Couple rolls more than enough.
g
Posted:
Mon Apr 09, 2007 2:48 pm
by Keith B
Great...thanks for all the "advises" on nailing, or should I say, sealing this topic down.
Posted:
Mon Apr 09, 2007 5:06 pm
by madjack
Geron wrote:madjack wrote:EVIL BLACK STUFF...aka auto windshield sealant/adhesive..........................
g
G, the couple of things we have tried to remove, came easily enough with a putty knife worked under the edge to start it up...the EBS forms a rubber type seal and seems to work very well...by the way, I agree that putty tape is good stuff as well...make sure it is somewhat warm and it will "squish" out real good...
p.s. don't know about long term EBS characteristics.........MJ
Posted:
Mon Apr 09, 2007 6:01 pm
by Gaston
I vote for 3
if you just use the putty tape, you will be trying to clean the dust and crap that sticks to it off. It tends to bleed out, and dirt and crud loves it.
You can use it to set the parts, then clean off the squeeze out and seal around with a thin bead of geocel rv sealer. you will be much happier in the long run
Posted:
Mon Apr 09, 2007 7:20 pm
by asianflava
I used putty tape. The guy I bought the windows from gave me a roll. There was enough to do both windows and the Fantastic fan. It did "Squish out when I tightened the screws down but it doesn't bother me. If it did, all it would take is a razor blade to remove the excess.
Posted:
Tue Apr 10, 2007 8:15 am
by Keith B
Well, we have votes for a combination of all three... how 'bout that. I looked around the motorhome last night and there's a PILE of "sealant" around everything, windows, vents, etc. so I'm sure they used a combination of both too. Don't know if ya'll have ever heard of NP1, but it is the EXACT same color as aluminum and it has MUCH better characteristics than any silicone product (I'm not a fan of silicone).
I know it's been talked about before but... I can't find the thread..do you guys seal the TD to the frame, even if minimally. I was thinking about putting some putty tape between the body and the frame. Thought it'd help keep any "vibration" from wearing off my undercoating.
Posted:
Tue Apr 10, 2007 9:38 am
by madjack
Keith B wrote:.......do you guys seal the TD to the frame, even if minimally. I was thinking about putting some putty tape between the body and the frame. Thought it'd help keep any "vibration" from wearing off my undercoating.
Keith...we did...we built the body independent of the frame...when we set the body on the chassis, we applied a fat stripe of painters caulk(arcyliconized silicone) to the top of the steel and dropped the body on top of it...our thinking was much the same as yours...don't know how much diff it made BUT we did it anyway........
